Pool pump man-in-the-middle SDA/SCL with ESP32
Posted: Fri Apr 28, 2023 8:40 pm
Hey all I have found some code on GitHub that works with my pool pump but it seems my model is a little newer than the one they used on on their GitHub. Most things seem to work but what doesn't is that the buttons on the control board do not seem to call out correctly to the main board.
The code for the buttons look to be this:
The bulk of the data seems to be coming from void IRAM_ATTR Core1( void* p) {...
And perhaps within that is the button code?
I did the rest api call (http://192.168.1.173:8080/api/v1/intex/swg/status) and got this:
So I know it can communicate with it just fine. And I also did this debug rest api call (http://192.168.1.173:8080/api/v1/intex/swg/debug) and got this back:
Would be great if someone more knowledgeable at binary and SDA/SCL would help me find my buttons binary code so that I can send that code to the pool pumps main controller.
The GitHub> https://github.com/jingsno/intex-swg-iot
#define BUTTON_BOOST 0x44
#define BUTTON_TIMER 0x46
#define BUTTON_POWER 0x4C
#define BUTTON_LOCK 0x4E
#define BUTTON_SELF_CLEAN 0x74And perhaps within that is the button code?
if (sendingKeyCode) {
if (totalBitsSent < 8) {
digitalWrite(dataPin, (buttonStatus << totalBitsSent) & 0x80 ? HIGH : LOW);
totalBitsSent++;
// FALLING edge 8 while sending keycode
else if (totalBitsSent == 8) {
// Receive ACK
pinMode(dataPin, GPIO_MODE_INPUT);
digitalWrite(dataPin, HIGH);
totalBitsSent++;
// FALLING edge 9 while sending keycode
else {
sendingKeyCode = false;
totalBitsSent = 0;
}Code: Select all
"data": {
"display": {
"status": "ON",
"brightness": 3,
"current_code": "."
"status": {
"power": "STANDBY",
"boost": "OFF",
"sleep": "OFF",
"o3_generation": "OFF",
"pump_low_flow": "OFF",
"low_salt": "OFF",
"high_salt": "OFF",
"service": "OFF"
"mode": {
"working": false,
"programming": false
}Code: Select all
"data": {
"powerStatus": "0x01",
"statusDigit1": "0x00",
"statusDigit2": "0x02",
"statusDigit3": "0x00",
"displayingDigit1": "0x00",
"displayingDigit2": "0x02",
"current_code": ".",
"readBuffer": "[0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X00, 0X00]",
"compilation_date": "Apr 27 2023",
"compilation_time": "16:20:36",
"otaUpdating": false,
"removeWifiConfig": false,
"machineON": true
"wifiReconnecting": false,
"readingMaster": true,
"sendingKeyCode": false
}The GitHub> https://github.com/jingsno/intex-swg-iot
