We have an ethernet device based on ESP32. So no Wifi, but I do not think it is related to Ethernet or Wifi frontend.
Using ADF2.5 (and IDF4.4.4)
I am struggling with a problem concerning open WebSocket connections.
We have a listener that holds open Websocket connections to control the ESP via a website.
So far everything is working, but:
If we have an open Websocket connection from a laptop/computer to the ESP and then plugging the network cable off the laptop, then instantly the heap decreases until empty
I tried to figured out where this is happening, and it seems to be a problem that the TCP connection is still opened, but the remote client is not present any longer.
Attached the piece of my code where the problem comes up:
static void ws_async_send(void *arg)
struct async_resp_arg *resp_arg = (async_resp_arg_t*)arg;
httpd_handle_t hd = resp_arg->hd;
int fd = resp_arg->fd;
httpd_ws_frame_t ws_pkt;
memset(&ws_pkt, 0, sizeof(httpd_ws_frame_t));
if(resp_arg != NULL) {
ws_pkt.payload = (uint8_t*)resp_arg->message;
ws_pkt.len = strlen(resp_arg->message);
ws_pkt.type = HTTPD_WS_TYPE_TEXT;
httpd_ws_send_frame_async(hd, fd, &ws_pkt);
free(resp_arg->message);
free(resp_arg);
void _ws_server_send_messages(const char* mymessage, httpd_req_t* req)
if (!_is_websocket_api_init) { // httpd might not have been created by now
ESP_LOGD(TAG, "Websocket not yet initialized");
return;
if(req == NULL) { //broadcast to all clients
size_t clients = WS_MAX_CLIENTS;
int client_fds[WS_MAX_CLIENTS];
if (httpd_get_client_list(wsServer, &clients, client_fds) == ESP_OK) {
for (size_t i=0; i < clients; ++i) {
int sock = client_fds[i];
if (httpd_ws_get_fd_info(wsServer, sock) == HTTPD_WS_CLIENT_WEBSOCKET) {
//ESP_LOGE(TAG, "Active client (fd=%d) -> sending async message", sock);
struct async_resp_arg *resp_arg = (async_resp_arg_t*)malloc(sizeof(struct async_resp_arg));
resp_arg->hd = wsServer;
resp_arg->fd = sock;
if(mymessage != NULL)
resp_arg->message = strdup(mymessage);
if (httpd_queue_work(resp_arg->hd, ws_async_send, resp_arg) != ESP_OK) {
free(resp_arg);
ESP_LOGE(TAG, "httpd_queue_work failed!");
else
ESP_LOGV(TAG, "Client (fd=%d) no WS:%d", sock, httpd_ws_get_fd_info(wsServer, sock));
ESP_LOGE(TAG, "httpd_get_client_list failed!");
return;
} else { //send to specific Client
resp_arg->hd = req->handle;
resp_arg->fd = httpd_req_to_sockfd(req);
if (httpd_queue_work(req->handle, ws_async_send, resp_arg) != ESP_OK) {
free(resp_arg);
return;
}What I tried so far:
- Setting up the SO_LINGER, that the socket will be forced to close. -> Better because the socket is freed after some time and not blocked, but the free heap decreases too fast to wait for this, because we are sending lots of messages to the client when connected.
- Build a FreeRTOS Queue around our "need to send" packets to have an upper limit of memory consumption, even if the callback is not called any more, then the queue is full and drops needed packets and clears on the next try when Websocket is recovered -> helps me to ensure the rest of the ESP having enough space to run properly, but it is only a bad workaround for the Websocket API itself.
Do you have an idea what is happening there and how to avoid this state that the callback is not called anymore, how to do a better memory management when using the httpd_queue_work() function, or is this a bug somewhere inside IDF?
If you need further information I can share, I tried to reduce the posted code to a minimum.
Thanks a lot if someone has an idea.
