TCP ESP32 two-way communication
munand6
Postby munand6 » Fri May 12, 2023 9:57 am
Hello everyone, I found on the net a code for a two-way communication between two Wifi devices, via TCP. It's quite simple and works well, the only problem is that if one of the two switches off, when you switch it on again it doesn't connect, you have to turn them both off to re-establish the connection.
I made various tests but I can't, I ask, can someone help me? for me and for other people, because this sketch could be very offensive to others.
Thank you
Code: Untitled.cpp Select all
#include <WiFi.h>
const char* ssid = "ESP32-AP";
const uint16_t portNumber = 50000; WiFiServer server(portNumber);
WiFiClient client;
bool connected = false;
Serial.begin(115200); Serial.println();
Serial.print("Setting AP (Access Point)…");
WiFi.softAP(ssid);
IPAddress IP = WiFi.softAPIP();
Serial.print(" -> IP address: "); Serial.println(IP);
server.begin();
if (!connected) {
delay(5000);
client = server.available();
if (client) {
Serial.println("Got a client !");
if (client.connected()) {
Serial.println("and it's connected!");
connected = true;
Serial.println("but it's not connected!");
client.stop();
while (client.available()) Serial.write(client.read());
while (Serial.available()) {
char r = Serial.read();
Serial.write(r);
client.write(r);
Serial.println("Client is gone");
client.stop();
connected = false;
#include <WiFi.h>
IPAddress serverIP;
WiFiClient client;
Serial.print("Connecting to SSID:"); Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
WiFi.begin(ssid);
delay(500);
Serial.write('.');
Serial.println(".\nConnected");
Serial.print("Local IP = "); Serial.println(WiFi.localIP());
serverIP = WiFi.gatewayIP();
Serial.flush();
if (! connected) {
if (client.connect(serverIP, portNumber)) {
Serial.print("Connected to Gateway IP = "); Serial.println(serverIP);
connected = true;
Serial.print("Could NOT connect to Gateway IP = "); Serial.println(serverIP);
delay(500);
Serial.write(r);
client.write(r);}
