how to point to older esp32 library
tjodork
Postby tjodork » Mon May 15, 2023 4:03 am
in the arduino gui... i include the library
https://raw.githubusercontent.com/espre ... index.json
that is at V2.0.9
I'm getting unexpected errors and would like to point to V2.0.3 which I can scroll down and find at
https://github.com/espressif/arduino-esp32/releases
is there a way to point to that V2.0.3 library so I can compile with that level just to sanity check if issues are related to newer library ?
If I can't do that...if I download the zip file ...where would I put the files and what would i have to do?..
Thx
lbernstone
Re: how to point to older esp32 library
Postby lbernstone » Mon May 15, 2023 4:06 pm
There are instructions for manual installation at https://docs.espressif.com/projects/ard ... lling.html.
The location for manual installs is <sketchbook_dir>/hardware/espressif/esp32. Using git will allow you to easily checkout whichever version you want to build against (you need to restart arduino after a checkout).
Users browsing this forum: Baidu [Spider] and 2 guests
