Esp32-s3 uart level for rs485
Glyderworm
Postby Glyderworm » Tue May 16, 2023 7:07 am
Im currently trying to build a simple plc with an esp32-s3.
There i want to integrate a RS485 interface but i have a few questions.
What is the logic level of the uart of the esp? 5V or 3.3V?
And does anyone of you have an idea if i should do a half or full duplex rs485?
Thanks in advance :)
Re: Esp32-s3 uart level for rs485
Postby Sprite » Tue May 16, 2023 8:15 am
ESP32 GPIO is all 3.3V. Technically, RS485 is always half-duplex; if you want full-duplex you'd probably use RS422.
Glyderworm
Postby Glyderworm » Wed May 17, 2023 9:17 am
thanks for the answer :)
i found and ordered the correct board now.
But since this board uses UART and i wanna connect as much IO as possible, there is another question.
The Dev-Kit of the ESP32-S3 has 2 micro USB ports.
So to save some IO pins i thought i could use one of those for my RS485 Board.
Is this possible or just stupid?
I just know that i need one micro usb to flash my programs to the ESP, for communicating over the serial monitor and maybe for debugging. So because both can do that, is there really a use for both of them or is there something i am missing?
Can i use both for these things?
Users browsing this forum: markkuk and 1 guest
