esp32-c6 and external PSRAM?
lerebel103@gmail.com
Postby lerebel103@gmail.com » Thu May 18, 2023 6:22 am
Hi there,
Is it possible to add external SPI PSRAM to esp32-c6 and have it work seamlessly with esp-idf as in past SoCs? Unlike prior modules, it seems esp32-c6 series SOCs do not come with an external PSRAM option.
Thanks for any pointers.
Kind Reagards,
Will.
Re: esp32-c6 and external PSRAM?
Postby Sprite » Thu May 18, 2023 8:56 am
No, sorry, the C6 (and all of the current members of the C series, for that matter) lack the internal hardware to incorporate PSRAM into their memory map.
Postby lerebel103@gmail.com » Thu May 18, 2023 1:11 pm
Ha! Thank you for confirming, that makes sense now.
Is there an ESP32 series with WiFi6, or will there be one soon, where PSRAM is offered?
Kind Regards,
Will.
Postby Sprite » Fri May 19, 2023 8:05 am
There likely will be at some point, but at this moment no S-series chips with WiFi6 has been announced. (In the shorter term, when the radio-less but pretty high spec ESP32-P4 gets to market, we'll have some way of pairing it with a C6, allowing you to have a high-spec solution capable of WiFi6.)
Postby lerebel103@gmail.com » Mon May 22, 2023 11:06 am
No problem, thanks for the info.
Look forward to a solution in this space, particularly with ultra low power possibilities of WiFi6 and TWT.
Will.
ESP_igrr
Postby ESP_igrr » Fri Feb 23, 2024 3:20 pm
The recently-announced ESP32-C61 (lower cost version of ESP32-C6) will include PSRAM support to compensate for the smaller amount of the internal SRAM.
Users browsing this forum: No registered users and 6 guests
