Hi everyone,
I am currently working on multiple projects on esp32, have been doing so for a while. However, I'm not a computer specialist by any means so forgive my ignorance, I have never encountered the following, nor have I done anything to trigger it voluntarily.
Whenever I try to compile any code, even an empty sketch, I get the following output, shown below, when I try to compile. It is an error not with the IDE, but the the esp32 package.
I have tried only uninstalling & reinstalling IDE and package, I believe the error is in the line "cmd /c if exist...", but i don't know what to go on from there. Any help would be appreciated.
C:\Users\jlgpk\Desktop\Engineering\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\jlgpk\Desktop\Engineering\Arduino\hardware -hardware C:\Users\jlgpk\AppData\Local\Arduino15\packages -tools C:\Users\jlgpk\Desktop\Engineering\Arduino\tools-builder -tools C:\Users\jlgpk\Desktop\Engineering\Arduino\hardware\tools\avr -tools C:\Users\jlgpk\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\jlgpk\Desktop\Engineering\Arduino\libraries -libraries C:\Users\jlgpk\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=external,PSRAM=disabled,PartitionScheme=huge_app,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\jlgpk\AppData\Local\Temp\arduino_build_255807 -warnings=none -build-cache C:\Users\jlgpk\AppData\Local\Temp\arduino_cache_483686 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.esptool_py.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.mkspiffs.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.openocd-esp32.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20220706 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20220706.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20220706 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -verbose C:\Users\jlgpk\Documents\Arduino\Fiver\ime2023\ESP32_2G\ESP32_2G.ino
C:\Users\jlgpk\Desktop\Engineering\Arduino\arduino-builder -compile -logger=machine -hardware C:\Users\jlgpk\Desktop\Engineering\Arduino\hardware -hardware C:\Users\jlgpk\AppData\Local\Arduino15\packages -tools C:\Users\jlgpk\Desktop\Engineering\Arduino\tools-builder -tools C:\Users\jlgpk\Desktop\Engineering\Arduino\hardware\tools\avr -tools C:\Users\jlgpk\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\jlgpk\Desktop\Engineering\Arduino\libraries -libraries C:\Users\jlgpk\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=external,PSRAM=disabled,PartitionScheme=huge_app,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=115200,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\jlgpk\AppData\Local\Temp\arduino_build_255807 -warnings=none -build-cache C:\Users\jlgpk\AppData\Local\Temp\arduino_cache_483686 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.esptool_py.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.mkspiffs.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.openocd-esp32.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20220706 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20220706.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20220706 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch5.path=C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5 -verbose C:\Users\jlgpk\Documents\Arduino\Fiver\ime2023\ESP32_2G\ESP32_2G.ino
Using board 'esp32' from platform in folder: C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6
Using core 'esp32' from platform in folder: C:\Users\jlgpk\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6
cmd /c if exist "C:\\Users\\jlgpk\\Documents\\Arduino\\Fiver\\ime2023\\ESP32_2G\\partitions.csv" COPY /y "C:\\Users\\jlgpk\\Documents\\Arduino\\Fiver\\ime2023\\ESP32_2G\\partitions.csv" "C:\\Users\\jlgpk\\AppData\\Local\\Temp\\arduino_build_255807\\partitions.csv"
exit status 1
Error compiling for board ESP32 Dev Module.
exit status 1. Error compiling for board ESP32 Dev Module.
Users browsing this forum: Bytespider and 2 guests
