ESP32 C3 delay between SPI transactions
khu8rt
Postby khu8rt » Sat May 20, 2023 1:27 pm
I am using ESP32 C3 Wroom 02 Dev kit to communicate to V9203 chip using SPI. I already tested the communication using Raspberry pi 3 and it works.
For a successul write opertaion, i have to send 3 * 32bit frames. but the ESP32 takes quite a long time between each SPI frame.
Between the first two frames its 5ms and for the last frame it takes 10ms.
Here is my code:
Code: Untitled.cpp Select all
/* SPI Slave example, sender (uses SPI master driver)
#include <stdio.h>
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include <unistd.h>
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/queue.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
#include "lwip/igmp.h"
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "nvs_flash.h"
#include "soc/rtc_periph.h"
#include "driver/spi_master.h"
#include "esp_log.h"
#include "esp_spi_flash.h"
#include "driver/gpio.h"
#include "esp_intr_alloc.h"
#define SENDER_HOST SPI2_HOST
static const char *TAG = "Energy meter";
#define GPIO_MOSI 7
#define GPIO_MISO 2
#define GPIO_SCLK 6
#define GPIO_CS 10
spi_device_handle_t Devicehandle;
spi_transaction_t init_spi(void)
spi_bus_config_t buscfg={
.mosi_io_num=GPIO_MOSI,
.miso_io_num=GPIO_MISO,
.sclk_io_num=GPIO_SCLK,
.quadwp_io_num=-1,
.quadhd_io_num=-1,
spi_device_interface_config_t devcfg={
.command_bits=0,
.address_bits=0,
.dummy_bits=0,
.input_delay_ns=0,
.clock_speed_hz=2000000,
.duty_cycle_pos=128,//50% duty cycle
.mode=3,
.spics_io_num=GPIO_CS,
.cs_ena_posttrans=0,
.queue_size=7
esp_err_t ret = -1;
spi_transaction_t trasactionHandle;
memset(&trasactionHandle, 0, sizeof(trasactionHandle));
ret=spi_bus_initialize(SENDER_HOST, &buscfg, SPI_DMA_CH_AUTO);
assert(ret==ESP_OK);
ret=spi_bus_add_device(SENDER_HOST, &devcfg, &Devicehandle);
return trasactionHandle;
uint sendSPIdata(uint8_t cmd, uint8_t data_h, uint8_t data_l, uint8_t chcksum, spi_transaction_t trasactionHandle){
ESP_LOGI(TAG, "Sending data to SPI bus");
int n=0;
esp_err_t ret = -1;
trasactionHandle.flags = SPI_TRANS_USE_RXDATA | SPI_TRANS_USE_TXDATA;
trasactionHandle.length = 32;
trasactionHandle.tx_data[0] = cmd;
trasactionHandle.tx_data[1] = data_h;
trasactionHandle.tx_data[2] = data_l;
trasactionHandle.tx_data[3] = chcksum;
ret=spi_device_transmit(Devicehandle, &trasactionHandle);
ESP_LOGI(TAG,"Sent: %d with return %d\n", trasactionHandle.tx_data[0],ret);
n++;
return ret;
uint spiWriteCmdData(unsigned char cmd0, uint dat, spi_transaction_t handle){
unsigned char cksum, cmdb;
uint send_dat = dat;
cmdb = (0x3f&cmd0) | 0x80;
cksum = ~((dat&0x00ff) + (dat>>8) + cmdb);
return sendSPIdata(cmdb,send_dat>>8,send_dat&0x00ff,cksum, handle);
void spiWRflash(uint addr, uint dat_h, uint dat_l, spi_transaction_t ha){
//printf("dat_l is %04X, dat_h is %04X address is %04X \n", dat_l,dat_h,addr);
spiWriteCmdData(0x08,dat_l, ha);
spiWriteCmdData(0x0A,dat_h,ha);
spiWriteCmdData(0x0c,addr,ha);
uint8_t iWriteRegister(uint data, uint16_t regAddress, spi_transaction_t h){
int ret = 0;
//printf("Writing %04X to %04X\n", data, regAddress);
spiWRflash(regAddress, (data>>16), data&0xffff, h);
return ret;
unsigned long readEMregister(unsigned int addr,spi_transaction_t han)
unsigned int dat_l, dat_h;
//printf("Reading register %04X \n", addr);
spiWriteCmdData(0x10, addr,han);
dat_l = spiWriteCmdData(0x12, addr,han);
dat_h = spiWriteCmdData(0x14, addr,han);
return (uint32_t)dat_h << 16 | (uint32_t)dat_l;
void vSetGPIOlevel(gpio_num_t number, int level)
esp_err_t iRetL = ESP_FAIL;
gpio_reset_pin(number);
iRetL = gpio_set_direction(number, GPIO_MODE_OUTPUT);
if (iRetL != ESP_OK){
ESP_LOGW(TAG, "Cannot set GPIO direction, V9203 mode might be set incorrectly");
iRetL = gpio_set_level(number, level);
ESP_LOGW(TAG, "Cannot set GPIO level, V9203 mode might be set incorrectly");
ESP_LOGI(TAG, "GPIO %i is set to %i",number, level);
void app_main(void)
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "Starting up!");
//vSetGPIOlevel(GPIO_NUM_18,1);
//vSetGPIOlevel(GPIO_NUM_19,1);
spi_transaction_t spitHandler = init_spi();
while(1){
sleep(1);
ret = iWriteRegister(0xDEADBEEF, 0xc001,spitHandler );
//break;
ESP_LOGI(TAG, "Program end!");
Need support, is ESP32 C3 not fast enough for my project or something wring in the SPI config
username
Re: ESP32 C3 delay between SPI transactions
Postby username » Sat May 20, 2023 5:21 pm
Can you try these 2 things to see if it helps.
trasactionHandle.flags = 0;
.duty_cycle_pos = 0
khu8rt
Postby khu8rt » Sun May 21, 2023 1:27 pm
Thanks for the response, the issue was the esp logs that i was printing before and after each transaction, removing them solved the issue.
Users browsing this forum: Barkrowler, Google [Bot], meta-externalagent and 3 guests
