I (10289) mesh: [scan]new scanning time:600ms, beacon interval:300ms
I (10289) mesh: <nvs>write layer:1
I (10289) [mwifi, 175]: Parent is connected
I (10299) [mwifi, 258]: State represents: 0
I (10299) wifi:BcnInt:102400, DTIM:2
I (10309) [router_example, 338]: event_loop_cb, event: 7
I (10309) [router_example, 346]: Parent is connected on station interface
I (10319) [router_example, 338]: event_loop_cb, event: 11
I (10319) mesh: <flush>upstream packets, connections(max):6, waiting:0, upQ:0
I (10329) [router_example, 338]: event_loop_cb, event: 14
I (10339) mesh: <flush>root
I (10339) mesh: [TXQ]<max:32>up(0, be:0), down(0, be:0), mgmt:0, xon(req:0, rsp:0), bcast:0, wnd(0, parent:00:00:00:00:00:00)
I (10349) mesh: [RXQ]<max:32 = cfg:32 + extra:0>self:0, <max:32 = cfg:32 + extra:0>tods:0
D (10729) [router_example, 253]: Node send, size: 72, data: {"src_addr": "60:55:f9:57
I (11429) esp_netif_handlers: sta ip: 192.168.4.5, mask: 255.255.255.0, gw: 192.168.4.1
I (11429) [router_example, 338]: event_loop_cb, event: 65
I (11429) [router_example, 359]: Root obtains the IP address. It is posted by LwIP stack automatically
I (11439) [router_example, 176]: TCP client write task is running
I (11449) [router_example, 91]: TCP client read task is running
I (11449) [router_example, 51]: Create a tcp client, ip: 192.168.4.1, port: 8989
W (11459) [router_example, 66]: socket connect, ret: -1, ip: 192.168.4.1, port: 8989
I (11969) [router_example, 51]: Create a tcp client, ip: 192.168.4.1, port: 8989
W (11969) [router_example, 66]: socket connect, ret: -1, ip: 192.168.4.1, port: 8989
I (11999) [router_example, 286]: System information, channel: 3, layer: 1, self mac: 60:55:f9:57
I (12469) [router_example, 51]: Create a tcp client, ip: 192.168.4.1, port: 8989
W (12469) [router_example, 66]: socket connect, ret: -1, ip: 192.168.4.1, port: 8989
I (12969) [router_example, 51]: Create a tcp client, ip: 192.168.4.1, port: 8989
W (12969) [router_example, 66]: socket connect, ret: -1, ip: 192.168.4.1, port: 8989
I (13469) [router_example, 51]: Create a tcp client, ip: 192.168.4.1, port: 8989
W (13469) [router_example, 66]: socket connect, ret: -1, ip: 192.168.4.1, port: 8989
