Error 102 on p_auth_cmpl->fail_reason
newhobby
Postby newhobby » Thu May 25, 2023 11:36 pm
What is error 102?
I can't seem to find what this error is and how to prevent it from happening.
https://github.com/espressif/esp-idf/bl ... _dm.c#L275
The define block only goes to 94.
#if (SMP_INCLUDED == TRUE)
#define BTA_DM_AUTH_FAIL_BASE                   (HCI_ERR_MAX_ERR + 10)
#define BTA_DM_AUTH_CONVERT_SMP_CODE(x)        (BTA_DM_AUTH_FAIL_BASE + (x))
#define BTA_DM_AUTH_SMP_PASSKEY_FAIL             BTA_DM_AUTH_CONVERT_SMP_CODE (SMP_PASSKEY_ENTRY_FAIL)
#define BTA_DM_AUTH_SMP_OOB_FAIL                (BTA_DM_AUTH_FAIL_BASE + SMP_OOB_FAIL)
#define BTA_DM_AUTH_SMP_PAIR_AUTH_FAIL          (BTA_DM_AUTH_FAIL_BASE + SMP_PAIR_AUTH_FAIL)
#define BTA_DM_AUTH_SMP_CONFIRM_VALUE_FAIL      (BTA_DM_AUTH_FAIL_BASE + SMP_CONFIRM_VALUE_ERR)
#define BTA_DM_AUTH_SMP_PAIR_NOT_SUPPORT        (BTA_DM_AUTH_FAIL_BASE + SMP_PAIR_NOT_SUPPORT)
#define BTA_DM_AUTH_SMP_ENC_KEY_SIZE            (BTA_DM_AUTH_FAIL_BASE + SMP_ENC_KEY_SIZE)
#define BTA_DM_AUTH_SMP_INVALID_CMD             (BTA_DM_AUTH_FAIL_BASE + SMP_INVALID_CMD)
#define BTA_DM_AUTH_SMP_UNKNOWN_ERR             (BTA_DM_AUTH_FAIL_BASE + SMP_PAIR_FAIL_UNKNOWN)
#define BTA_DM_AUTH_SMP_REPEATED_ATTEMPT        (BTA_DM_AUTH_FAIL_BASE + SMP_REPEATED_ATTEMPTS)
#define BTA_DM_AUTH_SMP_INVALID_PARAMETERS      (BTA_DM_AUTH_FAIL_BASE + SMP_INVALID_PARAMETERS)
#define BTA_DM_AUTH_SMP_INTERNAL_ERR            (BTA_DM_AUTH_FAIL_BASE + SMP_PAIR_INTERNAL_ERR)
#define BTA_DM_AUTH_SMP_UNKNOWN_IO              (BTA_DM_AUTH_FAIL_BASE + SMP_UNKNOWN_IO_CAP)
#define BTA_DM_AUTH_SMP_INIT_FAIL               (BTA_DM_AUTH_FAIL_BASE + SMP_INIT_FAIL)
#define BTA_DM_AUTH_SMP_CONFIRM_FAIL            (BTA_DM_AUTH_FAIL_BASE + SMP_CONFIRM_FAIL)
#define BTA_DM_AUTH_SMP_BUSY                    (BTA_DM_AUTH_FAIL_BASE + SMP_BUSY)
#define BTA_DM_AUTH_SMP_ENC_FAIL                (BTA_DM_AUTH_FAIL_BASE + SMP_ENC_FAIL)
#define BTA_DM_AUTH_SMP_RSP_TIMEOUT             (BTA_DM_AUTH_FAIL_BASE + SMP_RSP_TIMEOUT)
#endif  ///SMP_INCLUDED == TRUE
MicroController
Re: Error 102 on p_auth_cmpl->fail_reason
Postby MicroController » Sat May 27, 2023 10:09 pm
102 or 0x102?
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
