factory_demo编译过不去!!!
junshuliang
Postby junshuliang » Mon May 29, 2023 3:53 am
硬件box-lite,IDE:vsCode,IDFv4.4.4,hello world已编译!
Code: Untitled.cmake Select all
[SDK Configuration Editor]
-- Found Git: D:/Users/MECHREVO/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: D:/Users/MECHREVO/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Check for working C compiler: D:/Users/MECHREVO/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Check for working CXX compiler: D:/Users/MECHREVO/.espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Building ESP-IDF components for target esp32s3
Solving dependencies requirements
---------------------------ERROR--------------------------
CMake Error at D:/Users/MECHREVO/esp/esp-idf/tools/cmake/build.cmake:452 (message):
ERROR: Cannot establish a connection to the component registry. Are you
connected to the internet?
D:/Users/MECHREVO/esp/esp-idf/tools/cmake/project.cmake:384 (idf_build_process)
CMakeLists.txt:13 (project)
-----------------------END OF ERROR-----------------------
See also "D:/Projects/esp-box/examples/factory_demo/build/CMakeFiles/CMakeOutput.log".
Executing action: confserver
Running cmake in directory d:\projects\esp-box\examples\factory_demo\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 d:\projects\esp-box\examples\factory_demo"...
cmake failed with exit code 1
SDK Configuration editor confserver process exited with code: 2
看字面的意思,编译时还需要联网注册组件???
ESP_Rachel
Re: factory_demo编译过不去!!!
Postby ESP_Rachel » Tue May 30, 2023 8:50 am
您使用的是原始代码,没做改动么?
junshuliang
Postby junshuliang » Tue May 30, 2023 12:35 pm
是的,代码没动过,我还在搭环境 :geek:
Xuxin
Postby Xuxin » Thu Jun 01, 2023 1:46 am
那个,我看了下,你用的是 ESP-IDF 4.4 版本:
有两点:
1:包管理器需要ESP-IDF 5.0版本;
2:目前最新的 master 代码匹配 box-lite,你可以按照readme 中的版本说明,将工程版本切到指定版本;
例如 tag v0.3.0;
junshuliang
Postby junshuliang » Fri Jun 02, 2023 2:04 am
基本上找到原因,网络不行,最近封网升级,github的https链接经常被reset或超时,编译脚本没有重试机制。3个解决方方案:
1,脚本健壮化:如git命令失败,自动重试,并延长超时时间
2,构造gitee版编译脚本
3,提供无需联网的本地编译包
