Esp32 go offline automatic even the wifi is available
Esp32 go offline automatic even the wifi is available. It fix if I power off the esp and on again
Re: Esp32 go offline automatic even the wifi is available
What example are you using? esp-idf based or Arduino? Does your node not even connect to Wi-Fi, or does it connect to Wi-Fi but not to MQTT?
