esp_restart() results in Guru Meditation Error
rtborg
Postby rtborg » Wed Jun 07, 2023 7:23 am
I am attemting to restart an ESP32S3 into DFU mode, but each time I issue esp_restart(), I get an error:
/* CODE */
static void reboot_to_dfu(void)
    ESP_ERROR_CHECK(esp_register_shutdown_handler(usb_persist_shutdown_handler));
    s_queue_reboot = REBOOT_BOOTLOADER_DFU;
    esp_restart();
static void IRAM_ATTR usb_persist_shutdown_handler(void)
    if (s_queue_reboot == REBOOT_BOOTLOADER)
        // USB CDC Download
        chip_usb_set_persist_flags(USBDC_PERSIST_ENA);
        REG_WRITE(RTC_CNTL_OPTION1_REG, RTC_CNTL_FORCE_DOWNLOAD_BOOT);
    else if (s_queue_reboot == REBOOT_BOOTLOADER_DFU)
        // DFU Download
        chip_usb_set_persist_flags(USBDC_BOOT_DFU);
    else
        // USB Persist reboot
/* RESULTS */
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x3 (DOWNLOAD(USB/UART0))
Saved PC:0x40375bed
0x40375bed: esp_restart_noos_dig at C:/Users/null/esp/esp-idf/components/esp_system/esp_system.c:64 (discriminator 1)
waiting for download
Guru Meditation Error: Core 0 panic'ed (LoadProhibited)
Core 0 register dump:
PC      : 0x400511b1  PS      : 0x00060330  A0      : 0x80049188  A1      : 0x3fceb640
A2      : 0x00000000  A3      : 0x3ff1e3fb  A4      : 0x00000001  A5      : 0x00000000
A6      : 0x00000000  A7      : 0x00000088  A8      : 0x800533dc  A9      : 0x3fceb620
A10     : 0xfffffffb  A11     : 0x3fceeebc  A12     : 0x3fceefbc  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x00000006  SAR     : 0x0000001d  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x400570e8  LEND    : 0x400570f3  LCOUNT  : 0x00000000
Backtrace: 0x400511b1:0x3fceb640 0x40049185:0x3fceb670 0x400491e5:0x3fceb690 0x40043917:0x3fceb6b0 0x4004392a:0x3fceb6d0 0x40043c33:0x3fceb6f0 0x40034c45:0x3fceb710
Value of EXCVADDR hints that my code is dereferencing a NULL pointer. How can I find the offending code? My assumption was that tasks are stopped at the time esp_restart() finishes, but that appears to not be the case.
EDIT: Running xtensa-esp32s3-elf-addr2line.exe does not do any good. The addresses are also not found in the map file.
xtensa-esp32s3-elf-addr2line.exe -pfiaC -e .\build\firmware.elf 0x400511b1:0x3fceb640 0x40049185:0x3fceb670 0x400491e5:0x3fceb690 0x40043917:0x3fceb6b0 0x4004392a:0x3fceb6d0 0x40043c33:0x3fceb6f0 0x40034c45:0x3fceb710
0x400511b1: ?? ??:0
0x40049185: ?? ??:0
0x400491e5: ?? ??:0
0x40043917: ?? ??:0
0x4004392a: ?? ??:0
0x40043c33: ?? ??:0
0x40034c45: ?? ??:0
MicroController
Re: esp_restart() results in Guru Meditation Error
Postby MicroController » Wed Jun 07, 2023 1:41 pm
Are you sure a) you need to call chip_usb_set_persist_flags(...) and b) it is ok to call it in your context?
The original code seems to apply to the usb_console and also calls usb_dc_prepare_persist(), which may or may not be required before chip_usb_set_persist_flags(...).
What happens if you only use REG_WRITE(RTC_CNTL_OPTION1_REG, RTC_CNTL_FORCE_DOWNLOAD_BOOT) in the shutdown handler?
rtborg
Postby rtborg » Wed Jun 07, 2023 2:08 pm
Hi, tried the code without the chip_usb_set_persist_flags(USBDC_BOOT_DFU) statement, the result is the same.
MicroController
Postby MicroController » Wed Jun 07, 2023 4:20 pm
Oh, wait a minute.
Build:Mar 27 2021
Saved PC:0x40375bed
Seems like the chip did restart, and enter download mode.
So the panic looks like it's coming from the bootloader, not from your shutdown code; which would also explain why the backtrace cannot be mapped to your application. Can you try addr2line on build\bootloader\bootloader.elf?
rtborg
Postby rtborg » Wed Jun 07, 2023 8:09 pm
Thank you for the suggestion. Running addr2line on the bootloader .elf file also does not return any functions; inspected the map file - these addresses are not in there.
rtborg
Postby rtborg » Thu Jun 08, 2023 10:20 am
Updates:
1. I could not get the CDC console example working on esp32s3, due to compilation error:
C:/Users/null/esp/esp-idf/components/esp_system/port/soc/esp32s3/usb_console.c:69:1: error: static assertion failed: "usb_osglue_*_int is not multicore capable"
The flag CONFIG_ESP_CONSOLE_USB_CDC is set.
From reading the docs here, it looks that DFU will not work unless the CONFIG_ESP_CONSOLE_USB_CDC is set.
2. Setting CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG in menuconfig works; however when trying to reboot into DFU, I get the same Guru Meditation Error as before:
Build:Mar 27 2021
Saved PC:0x403758b9
0x403758b9: esp_restart_noos_dig at C:/Users/null/esp/esp-idf/components/esp_system/esp_system.c:64 (discriminator 1)
What I am trying to do is enter DFU mode from firmware. Is that possible on the S3 chip at all?
rtborg
Postby rtborg » Tue Jun 13, 2023 7:10 am
I would really appreciate input from ESP support here. I've spent a few days with no results and I need to know if I am on the wrong path.
levipope
Postby levipope » Thu Aug 31, 2023 10:50 pm
I am seeing that exact same error. I am not trying to reboot into DFU but rather in to serial download mode.
My app is using TinyUSB if that makes any difference. I was not sure if the USB peripheral needed to be reset somehow in that case.
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x2 (DOWNLOAD(USB/UART0))
Saved PC:0x40375ba9
Users browsing this forum: Baidu [Spider], Google [Bot], Qwantbot and 2 guests
