Hello I am modifying the esp-serial-flaser and I would like to know if there is a way to obtain the application's address. Almost always the bootloader address and the partition table address is the same. But how could I obtain the address of where to flash the firmware.bin dynamically?
Thank you
Get the value of the addresses dynamically
MicroController
Re: Get the value of the addresses dynamically
build/flasher_args.jsonCode: Select all
build/flash_argsRe: Get the value of the addresses dynamically
Thank you for answering, but could you give a more comprehensive response or an example where this is used?
Thank you
Thank you
MicroController
The build system writes the FLASH addresses for the binaries into these files in the build directory. There are the flash_*_args files which are passed to esptool.py by idf.py flash and the same information is also made available as a .json file for third-party software.
The .bin files themselves do not contain this meta-information. You could probably also parse the partition table (binary) and infer from partition names/types which binary is supposed to go where.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
