Using all the Peripherals, ESP32-c6
Aung Cho Oo
Postby Aung Cho Oo » Fri Jun 09, 2023 3:53 pm
I'm using esp32-c6 for my project and I need to use all the peripheral such as UART, I2C and SPI. But I can't use I2C and SPI together because they share the same pins. How can I solve this problem?
MicroController
Re: Using all the Peripherals, ESP32-c6
Postby MicroController » Fri Jun 09, 2023 3:58 pm
Just configure each interface to use the pins you want, see e.g. here.
Aung Cho Oo
Postby Aung Cho Oo » Fri Jun 09, 2023 5:35 pm
Does that mean I can use any pins for any peripherals?
MicroController
Postby MicroController » Fri Jun 09, 2023 6:16 pm
I believe there are some restrictions (ADC?...), but many of the pins should be usable by most of the peripherals. Check the respective API docs and/or reference manual for your SoC for details which peripherals can be mapped to which pins.
Users browsing this forum: Google [Bot], Qwantbot and 1 guest
