New to ESP32 / Auduino IDE cant get output from PWN possible config error
michpic
Postby michpic » Mon Jun 26, 2023 5:34 pm
Hi I used some example code from a tutorial for the ESP32 CAM robot with video and web interface. I have this working fine by just turning the I/O pins off on to my motor speed controller, but wanted to use PWM mainly because one motor runs a little faster than the other so I was going to use PWM to slow one down so when it goes Forward / Backwards is goes in a straight line not a curve. Unfortunately nothing happens when I connect to the web page - I see the video, but the buttons have no function. I wonder others use int PIN_NAME where the tutorial I used has a 'Define for the pin names. But other than that I have no idea whats up.
I heard PWM 1 was shared by the camera? So I have used 2,3,4,5 - 2 and 3 for motor 1 and 4/5 for motor 2.
Instead of setting a pin on, I set it on, then set the PWM on to the set value but no movement, I also moved the int declarations from setup at the end to where the other variables are deffined.
When just using Digital IO its fine and works so the hardware is sound. I spent a long time googling so thought it was time to post my first ESP32 issue....
Thanks in andvance!
I will try include my code if I get the quotes right:
  Rui Santos
  Complete instructions at https://RandomNerdTutorials.com/esp32-cam-projects-ebook/
  Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
#include "esp_camera.h"
#include <WiFi.h>
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "soc/soc.h"             // disable brownout problems
#include "soc/rtc_cntl_reg.h"    // disable brownout problems
#include "esp_http_server.h"
// Replace with your network credentials
const char* ssid = "removedmyssid";
const char* password = "removedmypassword";
#define PART_BOUNDARY "123456789000000000000987654321"
#define CAMERA_MODEL_AI_THINKER
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WITHOUT_PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM_B
//#define CAMERA_MODEL_WROVER_KIT
#if defined(CAMERA_MODEL_WROVER_KIT)
  #define PWDN_GPIO_NUM    -1
  #define RESET_GPIO_NUM   -1
  #define XCLK_GPIO_NUM    21
  #define SIOD_GPIO_NUM    26
  #define SIOC_GPIO_NUM    27
  #define Y9_GPIO_NUM      35
  #define Y8_GPIO_NUM      34
  #define Y7_GPIO_NUM      39
  #define Y6_GPIO_NUM      36
  #define Y5_GPIO_NUM      19
  #define Y4_GPIO_NUM      18
  #define Y3_GPIO_NUM       5
  #define Y2_GPIO_NUM       4
  #define VSYNC_GPIO_NUM   25
  #define HREF_GPIO_NUM    23
  #define PCLK_GPIO_NUM    22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
  #define RESET_GPIO_NUM    15
  #define XCLK_GPIO_NUM     27
  #define SIOD_GPIO_NUM     25
  #define SIOC_GPIO_NUM     23
  #define Y9_GPIO_NUM       19
  #define Y8_GPIO_NUM       36
  #define Y7_GPIO_NUM       18
  #define Y6_GPIO_NUM       39
  #define Y5_GPIO_NUM        5
  #define Y4_GPIO_NUM       34
  #define Y3_GPIO_NUM       35
  #define Y2_GPIO_NUM       32
  #define VSYNC_GPIO_NUM    22
  #define HREF_GPIO_NUM     26
  #define PCLK_GPIO_NUM     21
#elif defined(CAMERA_MODEL_M5STACK_WITHOUT_PSRAM)
  #define Y2_GPIO_NUM       17
#elif defined(CAMERA_MODEL_AI_THINKER)
  #define PWDN_GPIO_NUM     32
  #define XCLK_GPIO_NUM      0
  #define Y5_GPIO_NUM       21
  #define Y4_GPIO_NUM       19
  #define Y3_GPIO_NUM       18
  #define Y2_GPIO_NUM        5
#elif defined(CAMERA_MODEL_M5STACK_PSRAM_B)
  #define SIOD_GPIO_NUM     22
#else
  #error "Camera model not selected"
#endif
#define MOTOR_1_PIN_1    14
#define MOTOR_1_PIN_2    15
#define MOTOR_2_PIN_1    13
#define MOTOR_2_PIN_2    12
int Motor1_PWM_MAX = 255;
int Motor2_PWM_MAX = 255;
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t camera_httpd = NULL;
httpd_handle_t stream_httpd = NULL;
static const char PROGMEM INDEX_HTML[] = R"rawliteral(
<html>
  <head>
    <title>ESP32-CAM Robot</title>
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <style>
      body { font-family: Arial; text-align: center; margin:0px auto; padding-top: 30px;}
      table { margin-left: auto; margin-right: auto; }
      td { padding: 8 px; }
      .button {
        background-color: #2f4468;
        border: none;
        color: white;
        padding: 10px 20px;
        text-align: center;
        text-decoration: none;
        display: inline-block;
        font-size: 18px;
        margin: 6px 3px;
        cursor: pointer;
        -webkit-touch-callout: none;
        -webkit-user-select: none;
        -khtml-user-select: none;
        -moz-user-select: none;
        -ms-user-select: none;
        user-select: none;
        -webkit-tap-highlight-color: rgba(0,0,0,0);
      img {  width: auto ;
        max-width: 100% ;
        height: auto ;
    </style>
  </head>
  <body>
    <h1>ESP32-CAM Robot</h1>
    <img src="" id="photo" >
    <table>
      <tr><td colspan="3" align="center"><button class="button" onmousedown="toggleCheckbox('forward');" ontouchstart="toggleCheckbox('forward');" onmouseup="toggleCheckbox('stop');" ontouchend="toggleCheckbox('stop');">Forward</button></td></tr>
      <tr><td align="center"><button class="button" onmousedown="toggleCheckbox('left');" ontouchstart="toggleCheckbox('left');" onmouseup="toggleCheckbox('stop');" ontouchend="toggleCheckbox('stop');">Left</button></td><td align="center"><button class="button" onmousedown="toggleCheckbox('stop');" ontouchstart="toggleCheckbox('stop');">Stop</button></td><td align="center"><button class="button" onmousedown="toggleCheckbox('right');" ontouchstart="toggleCheckbox('right');" onmouseup="toggleCheckbox('stop');" ontouchend="toggleCheckbox('stop');">Right</button></td></tr>
      <tr><td colspan="3" align="center"><button class="button" onmousedown="toggleCheckbox('backward');" ontouchstart="toggleCheckbox('backward');" onmouseup="toggleCheckbox('stop');" ontouchend="toggleCheckbox('stop');">Backward</button></td></tr>
    </table>
   <script>
   function toggleCheckbox(x) {
     var xhr = new XMLHttpRequest();
     xhr.open("GET", "/action?go=" + x, true);
     xhr.send();
   window.onload = document.getElementById("photo").src = window.location.href.slice(0, -1) + ":81/stream";
  </script>
  </body>
</html>
)rawliteral";
static esp_err_t index_handler(httpd_req_t *req){
  httpd_resp_set_type(req, "text/html");
  return httpd_resp_send(req, (const char *)INDEX_HTML, strlen(INDEX_HTML));
static esp_err_t stream_handler(httpd_req_t *req){
  camera_fb_t * fb = NULL;
  esp_err_t res = ESP_OK;
  size_t _jpg_buf_len = 0;
  uint8_t * _jpg_buf = NULL;
  char * part_buf[64];
  res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
  if(res != ESP_OK){
    return res;
  while(true){
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      res = ESP_FAIL;
      if(fb->width > 400){
        if(fb->format != PIXFORMAT_JPEG){
          bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
          esp_camera_fb_return(fb);
          fb = NULL;
          if(!jpeg_converted){
            Serial.println("JPEG compression failed");
            res = ESP_FAIL;
          _jpg_buf_len = fb->len;
          _jpg_buf = fb->buf;
    if(res == ESP_OK){
      size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
      res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
    if(res == ESP_OK){
      res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
    if(res == ESP_OK){
      res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
    if(fb){
      fb = NULL;
      _jpg_buf = NULL;
    } else if(_jpg_buf){
      free(_jpg_buf);
      _jpg_buf = NULL;
    if(res != ESP_OK){
    //Serial.printf("MJPG: %uB\n",(uint32_t)(_jpg_buf_len));
  return res;
static esp_err_t cmd_handler(httpd_req_t *req){
  char*  buf;
  size_t buf_len;
  char variable[32] = {0,};
  buf_len = httpd_req_get_url_query_len(req) + 1;
  if (buf_len > 1) {
    buf = (char*)malloc(buf_len);
    if(!buf){
      httpd_resp_send_500(req);
      return ESP_FAIL;
    if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
      if (httpd_query_key_value(buf, "go", variable, sizeof(variable)) == ESP_OK) {
        free(buf);
        httpd_resp_send_404(req);
        return ESP_FAIL;
      free(buf);
      return ESP_FAIL;
    free(buf);
    return ESP_FAIL;
  sensor_t * s = esp_camera_sensor_get();
  int res = 0;
  if(!strcmp(variable, "forward")) {
    Serial.println("Forward");
    digitalWrite(MOTOR_1_PIN_1, 1);
    digitalWrite(MOTOR_1_PIN_2, 0);
    digitalWrite(MOTOR_2_PIN_1, 1);
    digitalWrite(MOTOR_2_PIN_2, 0);
    ledcWrite(2, Motor1_PWM_MAX);
    ledcWrite(3, 0);
    ledcWrite(4, Motor2_PWM_MAX);
    ledcWrite(5, 0);
  else if(!strcmp(variable, "left")) {
    Serial.println("Left");
    digitalWrite(MOTOR_1_PIN_1, 0);
    digitalWrite(MOTOR_1_PIN_2, 1);
    ledcWrite(2, 0);
    ledcWrite(3, Motor1_PWM_MAX);
    ledcWrite(5, 0);
  else if(!strcmp(variable, "right")) {
    Serial.println("Right");
    digitalWrite(MOTOR_2_PIN_1, 0);
    digitalWrite(MOTOR_2_PIN_2, 1);
    ledcWrite(3, 0);
    ledcWrite(4, 0);
    ledcWrite(5, Motor2_PWM_MAX);
  else if(!strcmp(variable, "backward")) {
    Serial.println("Backward");
    ledcWrite(2, 0);
    ledcWrite(4, 0);
  else if(!strcmp(variable, "stop")) {
    Serial.println("Stop");
    ledcWrite(2, 0);
    ledcWrite(3, 0);
    ledcWrite(4, 0);
    ledcWrite(5, 0);
  else {
    res = -1;
  if(res){
    return httpd_resp_send_500(req);
  httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
  return httpd_resp_send(req, NULL, 0);
void startCameraServer(){
  httpd_config_t config = HTTPD_DEFAULT_CONFIG();
  config.server_port = 80;
  httpd_uri_t index_uri = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = index_handler,
    .user_ctx  = NULL
  httpd_uri_t cmd_uri = {
    .uri       = "/action",
    .method    = HTTP_GET,
    .handler   = cmd_handler,
    .user_ctx  = NULL
  httpd_uri_t stream_uri = {
    .uri       = "/stream",
    .method    = HTTP_GET,
    .handler   = stream_handler,
    .user_ctx  = NULL
  if (httpd_start(&camera_httpd, &config) == ESP_OK) {
    httpd_register_uri_handler(camera_httpd, &index_uri);
    httpd_register_uri_handler(camera_httpd, &cmd_uri);
  config.server_port += 1;
  config.ctrl_port += 1;
  if (httpd_start(&stream_httpd, &config) == ESP_OK) {
    httpd_register_uri_handler(stream_httpd, &stream_uri);
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  pinMode(MOTOR_1_PIN_1, OUTPUT);
  pinMode(MOTOR_1_PIN_2, OUTPUT);
  pinMode(MOTOR_2_PIN_1, OUTPUT);
  pinMode(MOTOR_2_PIN_2, OUTPUT);
  digitalWrite(MOTOR_1_PIN_1, LOW);
  digitalWrite(MOTOR_1_PIN_2, LOW);
  digitalWrite(MOTOR_2_PIN_1, LOW);
  digitalWrite(MOTOR_2_PIN_2, LOW);
//PWM channels = 2,3,4,5
  ledcSetup(MOTOR_1_PIN_1, 5000, 8);
  ledcAttachPin(MOTOR_1_PIN_1, 2);
  ledcSetup(MOTOR_1_PIN_2, 5000, 8);
  ledcAttachPin(MOTOR_1_PIN_2, 3);
  ledcSetup(MOTOR_2_PIN_1, 5000, 8);
  ledcAttachPin(MOTOR_2_PIN_1, 4);
  ledcSetup(MOTOR_2_PIN_2, 5000, 8);
  ledcAttachPin(MOTOR_2_PIN_2, 5);
  Serial.setDebugOutput(false);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_VGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  // Wi-Fi connection
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Stream Ready! Go to: http://");
  // Start streaming web server
  startCameraServer();
Users browsing this forum: Google [Bot] and 5 guests
