Hi all, new here!
I’m working on an ESP32-WROOM-32E based device. The code is now ironed out and works.
I’d now like to implement physical tampering resistance security features, ie Secure Boot, Flash Encryption, Disable Debugging/JTAG, Burn eFuses.
As I understand these features/configs are only available and supported on ESP-IDF. Problem is the code base is developed on Arduino IDE, and I am not currently comfortable with porting over to ESP-IDF.
Is it possible to take the Arduino compiled .bin files (or some of) and encrypt + flash using the ESP-IDF tools espsecure.py, idf.py, esptool.py?
As you can I am new to this so feel free to point out my oversights.
Thanks for your help.
Secure boot Arduino code or flash using ESP-IDF
Re: Secure boot Arduino code or flash using ESP-IDF
You can add the Arduino libraries/functionality as a component to ESP-IDF. You'd still have to rework things like your build flow etc, but your code can mostly stay the same.
Thanks for getting back!
Any good guides / docs for porting Arduino->ESP?
The project has grown into multiple ino files, etc..
This will be my first full ESP-IDF experience so any pointers will be appreciated.
Users browsing this forum: Bing [Bot], ChatGPT-User and 5 guests
