new esp-idf-project with the use of components; #include driver/gpio.h: No such file or directory
mmueller
Postby mmueller » Fri Jun 30, 2023 8:38 pm
Hi together,
first of all, I don't have much experience in programming the ESP32 a the moment.
So the answer for my problem could be simple.
Currently, I have ESP-IDF v5.2 installed on my ubuntu host under the directory ~esp/esp-idf/.
Next to this directory I have created a simple esp-blinki-project with the command `idf.py create-project bliki`.
The main `blinki.c` includes among others `#include driver/gpio.h`.
When I use the comman `idf.py build` and `idf.py flash`, everithing works fine.
A LED, which is connected to the ESP32-Board, goes on and off... .
Now the Problem:
Next to my simple esp-blinki-project I created a new project to get experience with the use of own written components.
I used the the commands:
- idf.py create-project blinki-03
- Created the sub directory components for my component cledlight.
- mkdir components
- cd components
- idf.py create-component cledlight
The file cledlight.c includes among other includes `#include driver/gpio.h`.
When I try to build the project with the comman `idf.py build` I get the error message `fatal error: driver/gpio.h: No such file or directory`.
My attempts to include the esp-idf components (gpio.h ...) in the CMake-Files have so far been unsuccessful.
(I hope this post will be readable :? )
I would be very greatful if someone could help me.
Here you can see the code of the component cledlight:
[1] cledlight.c
Code: Untitled.c Select all
#include <stdio.h>
#include "cledlight.h"
#include "freertos/task.h"
#include "driver/gpio.h"
void config_blink(void){
gpio_set_direction(GPIO_NUM_5, GPIO_MODE_DEF_OUTPUT);
void blink_on(void){
gpio_set_level(GPIO_NUM_5, 1);
vTaskDelay(2000 / portTICK_PERIOD_MS);
gpio_set_level(GPIO_NUM_5, 0);
[2] include/cledlight.h
void config_blink(void);
void blink_on(void);
[3]CMakeLists.txt
Code: Untitled.txt Select all
idf_component_register(SRCS "cledlight.c"
INCLUDE_DIRS "include")
Here you can see the main:
[4] blinki-03.c
#include <stdio.h>
void app_main(void)
config_blink();
while(1){
blink_on();
[5] CmakeList.txt
idf_component_register(SRCS "blinki-03.c"
INCLUDE_DIRS ".")
Here you can see the "main"-CMakeLists.txt of the project.
[6] CMakeLists.txt
# For more information about build system see
# https://docs.espressif.com/projects/esp-idf/en/latest/api-guides/build-system.html
# The following five lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.16)
project(blinki-03)
Re: new esp-idf-project with the use of components; #include driver/gpio.h: No such file or directory
Postby Sprite » Sat Jul 01, 2023 3:34 am
You need to add a 'REQUIRES driver' to the idf_component_register of your component.
mmueller
Postby mmueller » Sat Jul 01, 2023 8:25 am
It works, i'm so happy :D
I tried so many things to solve this problem.
Many thanks for this hint.
joy586210
Postby joy586210 » Wed Nov 22, 2023 1:03 pm
thanks!
ikkesia
Postby ikkesia » Fri Oct 18, 2024 8:02 am
I have the same problem and can't solve it. Can you share your CMakeLists.txt ?
Users browsing this forum: Applebot, Baidu [Spider], PerplexityBot, Qwantbot and 6 guests
