ESP-IDF v5.1 - identifier "CONFIG_FREERTOS_HZ" is undefined
username
Postby username » Tue Jul 04, 2023 6:36 am
Just installed ESP-IDF v5.1.
Created a new project using the blink example, it compiles but shows red squiggles.
Screenshot 2023-07-04 013430.png (125.33 KiB) Viewed 15801 times
LochWatenan
Re: ESP-IDF v5.1 - identifier "CONFIG_FREERTOS_HZ" is undefined
Postby LochWatenan » Tue Jul 04, 2023 11:14 am
Same for me here with the HelloWorld example; missing are here:
* CONFIG_IDF_TARGET
* CONFIG_FREERTOS_HZ
The issue seems to exist for quite some time, see here: https://www.reddit.com/r/esp32/comments ... _examples/ (4yr ago)
When trying to #define the missing identifiers (before #include) I get a warning of a redefinition (inside some sdk header files).
I am totally new to the ESP32 (IDF) world, so currently do not really understand what is going on. But it seems the missing values are defined in the sdkconfig(.h) or config.env files.
So, I do not have a solution, but can confirm the behaviour.
I am using the Espressif IDF release v5.1 on VS Code v1.79.2 on Windows 11.
camztouch
Postby camztouch » Tue Aug 01, 2023 8:20 am
I have the same issue on idf 5.1 on Apple Silicon.
It still compiles, but feels wrong
igrr
Postby igrr » Tue Aug 01, 2023 9:44 am
Could you please check if you have compile_commands.json location correctly configured? See https://github.com/espressif/vscode-esp ... mmandsjson.
jhlee1
Postby jhlee1 » Mon Sep 11, 2023 7:16 am
I'm using VSCode v1.82 and extension Espressif IDF v1.6.4 on Windows 10.
I have the same problem after installing idf v5.1. Even existing projects using idf v5.0 occur the same problem.
I tried adding "compileCommands": "${workspaceFolder}\\build\\compile_commands.json" to the configurations in the c_cpp_properties.json file, but it doesn't work for me.
kmmaran
Postby kmmaran » Mon Sep 18, 2023 4:02 pm
I face the same issue and used the solution below and works for me. Please add
"${workspaceFolder}/build/config",
in the c_cpp_properties.json , see below
OR
from https://github.com/espressif/vscode-esp ... URATION.md
last section, please add
"compileCommands": "${workspaceFolder}/build/compile_commands.json"
Édipo Duanny
Postby Édipo Duanny » Mon Oct 09, 2023 9:51 pm
@kmmaran,
In my case, the problem was solved. Thank you.
Westfaliah
Postby Westfaliah » Thu Oct 26, 2023 2:49 pm
@kmmaran, Thank you!
MelbourneMick
Postby MelbourneMick » Sun Apr 21, 2024 2:50 pm
Thank you - it was driving me crazy!
TUHHSTUDENT
Postby TUHHSTUDENT » Tue May 28, 2024 6:27 pm
Thank you!
