error message ledc_isr_register()
zilizii
Postby zilizii » Sun Oct 29, 2017 3:16 pm
I am a new in the ESP32 world. My goal is to understnad the basics and I would like to use only the ESP-IDF API.
I have been read the LED Controller part, and I would like to use the end interrupt of a fade effect.
Channel is configured according to the demo
ledc_fade_func_install(0);
ledc_isr_register(&ledc_isr_fnc, NULL, ESP_INTR_FLAG_IRAM , NULL);
where the fnc:
void IRAM_ATTR ledc_isr_fnc( void * arg) {
	printf("OMG, it is works \n");
in the main:
	printf("1. LEDC fade up to duty = %d\n", LEDC_TEST_DUTY);
	for (ch = 0; ch < LEDC_TEST_CH_NUM; ch++) {
                ledc_set_fade_with_time(ledc_channel[ch].speed_mode,
                        ledc_channel[ch].channel, LEDC_TEST_DUTY, LEDC_TEST_FADE_TIME);
                ledc_fade_start(ledc_channel[ch].speed_mode,
                        ledc_channel[ch].channel, LEDC_FADE_NO_WAIT);
I guess this point of time the crash happens...
I got a nice error message:
abort() was called at PC 0x40081fb9 on core 0
Unfortunatelly I have not found too much info what I have to do for working.
Please help to me.
Trial - Error scenario for learning ESP32 :D
abcdcadb
Re: error message ledc_isr_register()
Postby abcdcadb » Tue Oct 31, 2017 8:09 am
HI,
there is an example about led in IDF, I strongly recommend you to run it first and later, modify it for your purpose,
about the problem you are facing (abort was called,...). i one time met when I wrongly configure I2C pins. so I guess that you did somethings related to hardware configuration. so, let try the example
zilizii
Postby zilizii » Tue Oct 31, 2017 9:29 am
Thank you for your response!
The example is working well. I would like to use the isr part because of I do not want to write and calculate fixed waiting times.
I would like to use the fade end interrupt to change the behaviour of the ledc.
The Documentation of the ESP-IDF clearly described I have to use the ledc_isr_register() fnc for this. When I added the the same ESP_INTR_FLAG_IRAM to the ledc_fade_func_install(ESP_INTR_FLAG_IRAM ); seems working, but not as expected. Maybe I missunderstand the whole mechanism. The Hardware documentation mentioned all of the led channels shoul have fade end interrupt. Seems every change the interrupt function called. I think I have to learn a lot.
I would like to ask anybody to create us a tutorial for this and may be the interrupt handlings as well. I do not want to use the Arduino core anymore. For me this is in the beggining of a learning process.
abcdcadb
Postby abcdcadb » Tue Oct 31, 2017 9:41 am
I am not sure for what is led_isr,what kind of peripheral module you want to configure for interrupt?
In case of IO interrupt (that detects the status switch on the IO pin), you may refer GPIO example
I tested interrupt functions of GPIO, timer I2c and spi of IDF2.0. idf3.0 i am not sure if there is any problem
zilizii
Postby zilizii » Tue Oct 31, 2017 2:31 pm
Hello
https://esp-idf.readthedocs.io/en/lates ... /ledc.html I just would like to use what the documentation said:
Use Interrupts
When configuring a LEDC channel, one of parameters selected within ledc_channel_config_t is ledc_intr_type_t and allows to enable an interrupt on fade completion.
Registration of a handler to service this interrupt is done by calling ledc_isr_register().
The configuration is the following:
ledc_timer_config_t ledc_timer = {
		.bit_num = LEDC_TIMER_13_BIT, // resolution of PWM duty
		.freq_hz = 5000,              // frequency of PWM signal
		.speed_mode = LEDC_HS_MODE,   // timer mode
		.timer_num = LEDC_HS_TIMER    // timer index
ledc_timer_config(&ledc_timer);
ledc_channel_config_t ledc_channel[LEDC_TEST_CH_NUM] = { { .channel =
		LEDC_HS_CH2_CHANNEL, .duty = 0, .gpio_num = LEDC_HS_CH2_GPIO,
		.speed_mode = LEDC_HS_MODE, .timer_sel = LEDC_HS_TIMER, .intr_type =
				LEDC_INTR_FADE_END }, };
I got too many interrupt, I would like to get only 1 when the fade itself ended.
Thank you for your support!
zilizii
Postby zilizii » Tue Oct 31, 2017 3:21 pm
In the technical documentation there is a small part:
LEDC_DUTY_CHNG_END_HSCHn_INT in the Chapter 13.2.4 Interrupts.
How I am able to invoke ISR function when this event happens?
I guess the ledc_isr_register() fnc may be the answer....
krzychb
Contact:
Postby krzychb » Tue Oct 31, 2017 7:48 pm
Hello zilizii,
What do you mean? Do you see any interrupts triggered?
If you do not see any interrupts triggered, do you check the value returned by 'ledc_isr_register()'?
What is the value?
zilizii
Postby zilizii » Tue Oct 31, 2017 8:32 pm
Hello
last time I used the following part of code to catch the interrupt.
I guessing I am doing something wrong / not understand the concept or missunderstand between the ESP-IDF documentation and my mind. Any help is a welcome....
I got 257 decimal value 151 times before the ESP32 reset itself....
Which is meaning :
100000001
LEDC_DUTY_CHNG_END_HSCHn_INT_ST|LEDC_HSTIMER0_OVF_INT_ST
void IRAM_ATTR ledc_isr_fnc(void * arg) {
	 uint32_t l_ulCounter = REG_READ(0x3FF59180);
	 BaseType_t xHigherPriorityTaskWoken;
	 xQueueSendFromISR(queue, &l_ulCounter, &xHigherPriorityTaskWoken);
	 if( xHigherPriorityTaskWoken )
	         /* Actual macro used here is port specific. */
		 	 portYIELD_FROM_ISR();
void vprinttask(void * parameters) {
	uint32_t l_ulcurrent = 0;
	printf("Print Task started");
	while (1) {
		if (xQueueReceive(queue, &l_ulcurrent, portMAX_DELAY)) {
			printf("%i event happened...\n", l_ulcurrent);
			printf("Too long wait to Message");
Results:
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:5424
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:12028
entry 0x40078f24
W (95) boot: PRO CPU has been reset by WDT.
W (95) boot: WDT reset info: PRO CPU PC=0x400803c0
W (95) boot: WDT reset info: APP CPU PC=0x400dd3a0
I (114) boot: ESP-IDF v3.0-dev-349-g2861f3e8-dirty 2nd stage bootloader
I (136) boot: compile time 20:40:10
I (149) boot: Enabling RNG early entropy source...
I (166) boot: SPI Speed : 40MHz
I (179) boot: SPI Mode : DIO
I (192) boot: SPI Flash Size : 4MB
I (204) boot: Partition Table:
I (216) boot: ## Label Usage Type ST Offset Length
I (238) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (262) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (285) boot: 2 factory factory app 00 00 00010000 00100000
I (308) boot: End of partition table
I (321) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x05284 ( 21124) map
I (372) esp_image: segment 1: paddr=0x000152ac vaddr=0x3ffb0000 size=0x01eb4 ( 7860) load
I (386) esp_image: segment 2: paddr=0x00017168 vaddr=0x40080000 size=0x00400 ( 1024) load
I (405) esp_image: segment 3: paddr=0x00017570 vaddr=0x40080400 size=0x07450 ( 29776) load
I (469) esp_image: segment 4: paddr=0x0001e9c8 vaddr=0x400c0000 size=0x00000 ( 0) load
I (470) esp_image: segment 5: paddr=0x0001e9d0 vaddr=0x00000000 size=0x01640 ( 5696)
I (498) esp_image: segment 6: paddr=0x00020018 vaddr=0x400d0018 size=0x0fa60 ( 64096) map
I (602) boot: Loaded app from partition at offset 0x10000
I (602) boot: Disabling RNG early entropy source...
I (604) cpu_start: Pro cpu up.
I (615) cpu_start: Starting app cpu, entry point is 0x40080d18
I (0) cpu_start: App cpu up.
I (647) heap_init: Initializing. RAM available for dynamic allocation:
I (668) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (687) heap_init: At 3FFB26C8 len 0002D938 (182 KiB): DRAM
I (706) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (725) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (745) heap_init: At 40087850 len 000187B0 (97 KiB): IRAM
I (764) cpu_start: Pro cpu start user code
I (822) cpu_start: Starting scheduler on PRO CPU.
I (190) cpu_start: Starting scheduler on APP CPU.
Print Task started
end
257 event happened...
257 event hets Jun 8 2016 00:22:57
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
If I used a volatile uint32_t -- > incrementation the value was mot increment constantly sometime +500 difference I can get in the UART.
zilizii
Postby zilizii » Tue Oct 31, 2017 8:43 pm
I made a mistake
LEDC_DUTY_CHNG_END_HSCHn_INT_ST|LEDC_HSTIMER0_OVF_INT_ST was incorrect
LEDC_DUTY_CHNG_END_HSCHn_INT_RAW|LEDC_HSTIMER0_OVF_INT_RAW should be correct.....
user4_esp32
Postby user4_esp32 » Sun Nov 26, 2017 4:52 pm
Hello zilizii,
Thank you for posting your work with the led controller interrupts. I would like to use the LEDC_HSTIMER0_OVF_INT interrupt--would you please post your code that shows how your created an interrupt handler that responds to the LEDC_HSTIMER0_OVF_INT, as well as how you enabled the LEDC_HSTIMER0_OVF_INT? Are you changing the LEDC_INT_ENA_REG register directly?
Thanks.
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 3 guests
