I've got an Sillicognition wESP32 (revision 7 with RTL8201 chip) connected to my computer via the programmer.
If I run the code below (the code originates from the documentation), I'll get the following error:
Code: Untitled.txt Select all
19:55:22.704 -> E (133) rtl8201: rtl8201_pwrctl(252): power up timeout
19:55:22.704 -> E (133) rtl8201: rtl8201_init(334): power control failed
19:55:22.746 -> E (133) esp_eth: esp_eth_driver_install(215): init phy failedCode: Untitled.cpp Select all
#include <ETH.h>
#include <WebServer.h>
#include <ESPmDNS.h>
// Web server
WebServer server(80);
// HTTP handlers
void handleRoot() {
server.send(200, "text/plain", "Hello from wESP32!\n");
void handleNotFound() {
server.send(404, "text/plain", String("No ") + server.uri() + " here!\n");
void setup(){
// Start the Ethernet, revision 7+ uses RTL8201
ETH.begin(0, -1, 16, 17, ETH_PHY_RTL8201);
// The defaults work for older revision boards
// ETH.begin();
// You can browse to wesp32demo.local with this
MDNS.begin("wesp32demo");
// Bind HTTP handler
server.on("/", handleRoot);
server.onNotFound(handleNotFound);
// Start the Ethernet web server
server.begin();
// Add service to MDNS-SD
MDNS.addService("http", "tcp", 80);
void loop(){
server.handleClient();
