Which is the most power efficient ESP32 chip
zazas321
Postby zazas321 » Wed Jul 19, 2023 7:16 pm
Hello. I am working on a project that requires connecting to MQTT client, sending some data and then going to sleep.
The form factor of the device should be as small as possible but the requirement #1 is ultra low power.
I have been doing some research but could not find concrete answer on which ESP32 module/chip is most suitable for ultra low power applications.
I have been looking at:
ESP-WROOM-32
ESP32-PICO-D4
ESP32-C2
MicroController
Re: Which is the most power efficient ESP32 chip
Postby MicroController » Thu Jul 20, 2023 5:47 pm
Check the section "current consumption" in the datasheets of the SoCs or modules you're interested in.
If all you need is basically WiFi+MQTT, then the -C2 may be the lowest power option to get the job done. Definitely prefer a single-core model over a dual-core.
Note however that (WiFi) RF consumes much more energy than the rest of the chip combined. (For the -C2 (datasheet): CPU+peripherals ~15mA, WiFi RF ~50-350mA) The power required for WiFi RF is pretty consistent across the ESPs, so you may want to take into account that any power savings in the "core" may hardly make a difference if WiFi needs to be active whenever the chip is not sleeping.
Users browsing this forum: Amazon [Bot] and 2 guests
