ESP_BLE_MESH_MODEL_CFG_SRV
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV
ESP_BLE_MESH_MODEL_GEN_POWER_ONOFF_SRV
ESP_BLE_MESH_MODEL_GEN_POWER_ONOFF_SETUP_SRV
ESP_BLE_MESH_MODEL_GEN_LEVEL_SRV
ESP_BLE_MESH_MODEL_LIGHT_LIGHTNESS_SRV
ESP_BLE_MESH_MODEL_LIGHT_LIGHTNESS_SETUP_SRV
Any suggestions? Here's the full example code:
/* main.c - Application main entry point */
* Copyright (c) 2017 Intel Corporation
* Additional Copyright (c) 2018 Espressif Systems (Shanghai) PTE LTD
* SPDX-License-Identifier: Apache-2.0
#include <stdio.h>
#include <string.h>
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_ble_mesh_defs.h"
#include "esp_ble_mesh_common_api.h"
#include "esp_ble_mesh_networking_api.h"
#include "esp_ble_mesh_provisioning_api.h"
#include "esp_ble_mesh_config_model_api.h"
#include "esp_ble_mesh_generic_model_api.h"
#include "esp_ble_mesh_lighting_model_api.h"
#include "esp_ble_mesh_local_data_operation_api.h"
#include "board.h"
#include "ble_mesh_example_init.h"
#define TAG "EXAMPLE"
#define CID_ESP 0x02E5
extern struct _led_state led_state[3];
static uint8_t dev_uuid[16] = {0xdd, 0xdd};
static esp_ble_mesh_cfg_srv_t config_server = {
.relay = ESP_BLE_MESH_RELAY_DISABLED,
.beacon = ESP_BLE_MESH_BEACON_ENABLED,
#if defined(CONFIG_BLE_MESH_FRIEND)
.friend_state = ESP_BLE_MESH_FRIEND_ENABLED,
#else
.friend_state = ESP_BLE_MESH_FRIEND_NOT_SUPPORTED,
#endif
#if defined(CONFIG_BLE_MESH_GATT_PROXY_SERVER)
.gatt_proxy = ESP_BLE_MESH_GATT_PROXY_ENABLED,
#else
.gatt_proxy = ESP_BLE_MESH_GATT_PROXY_NOT_SUPPORTED,
#endif
.default_ttl = 7,
/* 3 transmissions with 20ms interval */
.net_transmit = ESP_BLE_MESH_TRANSMIT(2, 20),
.relay_retransmit = ESP_BLE_MESH_TRANSMIT(2, 20),
ESP_BLE_MESH_MODEL_PUB_DEFINE(onoff_pub_0, 2 + 3, ROLE_NODE);
static esp_ble_mesh_gen_onoff_srv_t onoff_server_0 = {
.rsp_ctrl.get_auto_rsp = ESP_BLE_MESH_SERVER_AUTO_RSP,
.rsp_ctrl.set_auto_rsp = ESP_BLE_MESH_SERVER_AUTO_RSP,
ESP_BLE_MESH_MODEL_PUB_DEFINE(onoff_pub_1, 2 + 3, ROLE_NODE);
static esp_ble_mesh_gen_onoff_srv_t onoff_server_1 = {
.rsp_ctrl.set_auto_rsp = ESP_BLE_MESH_SERVER_RSP_BY_APP,
/* Generic Power OnOff state related context */
static esp_ble_mesh_gen_onpowerup_state_t onpowerup_state;
/* Generic Power OnOff Server related context */
ESP_BLE_MESH_MODEL_PUB_DEFINE(power_onoff_pub, 2 + 1, ROLE_NODE);
static esp_ble_mesh_gen_power_onoff_srv_t power_onoff_server = {
.state = &onpowerup_state,
/* Generic Power OnOff Setup Server related context */
ESP_BLE_MESH_MODEL_PUB_DEFINE(power_onoff_setup_pub, 2 + 5, ROLE_NODE);
static esp_ble_mesh_gen_power_onoff_setup_srv_t power_onoff_setup_server = {
/* Generic Level Server related context */
ESP_BLE_MESH_MODEL_PUB_DEFINE(level_pub_0, 2 + 5, ROLE_NODE);
static esp_ble_mesh_gen_level_srv_t level_server_0 = {
/* Light Lightness state related context */
static esp_ble_mesh_light_lightness_state_t lightness_state;
/* Light Lightness Server related context */
ESP_BLE_MESH_MODEL_PUB_DEFINE(lightness_pub, 2 + 5, ROLE_NODE);
static esp_ble_mesh_light_lightness_srv_t lightness_server = {
.state = &lightness_state,
/* Light Lightness Setup Server related context */
ESP_BLE_MESH_MODEL_PUB_DEFINE(lightness_setup_pub, 2 + 5, ROLE_NODE);
static esp_ble_mesh_light_lightness_setup_srv_t lightness_setup_server = {
// TODO need to add dependent root mdoels to make lightness model work:
// In Bluetooth Mesh terminology, a "root model" and an "extension model" pertain to the definition and arrangement of models within an element of a node.
// Root Model: It is a standalone model that isn't extending any other models. It defines its own behavior and state independently.
// Extension Model: This type of model extends or builds upon another model (which could be a root model or another extension model). Essentially, it inherits certain behaviors or states from the models it extends and can add or override functions as needed.
static esp_ble_mesh_model_t root_models[] = {
ESP_BLE_MESH_MODEL_CFG_SRV(&config_server),
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV(&onoff_pub_0, &onoff_server_0),
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV(&onoff_pub_1, &onoff_server_1),
ESP_BLE_MESH_MODEL_GEN_POWER_ONOFF_SRV(&power_onoff_pub, &power_onoff_server),
ESP_BLE_MESH_MODEL_GEN_POWER_ONOFF_SETUP_SRV(&power_onoff_setup_pub, &power_onoff_setup_server),
ESP_BLE_MESH_MODEL_GEN_LEVEL_SRV(&level_pub_0, &level_server_0),
static esp_ble_mesh_model_t extend_model_0[] = {
ESP_BLE_MESH_MODEL_LIGHT_LIGHTNESS_SRV(&lightness_pub, &lightness_server),
ESP_BLE_MESH_MODEL_LIGHT_LIGHTNESS_SETUP_SRV(&lightness_setup_pub, &lightness_setup_server),
static esp_ble_mesh_elem_t elements[] = {
ESP_BLE_MESH_ELEMENT(0, root_models, ESP_BLE_MESH_MODEL_NONE),
ESP_BLE_MESH_ELEMENT(0, extend_model_0, ESP_BLE_MESH_MODEL_NONE),
static esp_ble_mesh_comp_t composition = {
.cid = CID_ESP,
.elements = elements,
.element_count = ARRAY_SIZE(elements),
/* Disable OOB security for SILabs Android app */
static esp_ble_mesh_prov_t provision = {
.uuid = dev_uuid,
#if 0
.output_size = 4,
.output_actions = ESP_BLE_MESH_DISPLAY_NUMBER,
.input_actions = ESP_BLE_MESH_PUSH,
.input_size = 4,
#else
.output_size = 0,
.output_actions = 0,
#endif
static int32_t bt_mesh_ceiling(float num)
int32_t inum = (int32_t)num;
if (num == (float)inum)
return inum;
return inum + 1;
static uint16_t convert_lightness_actual_to_linear(uint16_t actual)
float tmp = ((float)actual / UINT16_MAX);
return bt_mesh_ceiling(UINT16_MAX * tmp * tmp);
static void prov_complete(uint16_t net_idx, uint16_t addr, uint8_t flags, uint32_t iv_index)
ESP_LOGI(TAG, "net_idx: 0x%04x, addr: 0x%04x", net_idx, addr);
ESP_LOGI(TAG, "flags: 0x%02x, iv_index: 0x%08x", flags, iv_index);
board_led_operation(LED_G, LED_OFF);
static void example_change_led_state(esp_ble_mesh_model_t *model,
esp_ble_mesh_msg_ctx_t *ctx, uint8_t onoff)
uint16_t primary_addr = esp_ble_mesh_get_primary_element_address();
uint8_t elem_count = esp_ble_mesh_get_element_count();
struct _led_state *led = NULL;
uint8_t i;
if (ESP_BLE_MESH_ADDR_IS_UNICAST(ctx->recv_dst))
for (i = 0; i < elem_count; i++)
if (ctx->recv_dst == (primary_addr + i))
led = &led_state[i];
board_led_operation(led->pin, onoff);
else if (ESP_BLE_MESH_ADDR_IS_GROUP(ctx->recv_dst))
if (esp_ble_mesh_is_model_subscribed_to_group(model, ctx->recv_dst))
led = &led_state[model->element->element_addr - primary_addr];
else if (ctx->recv_dst == 0xFFFF)
static void example_handle_gen_onoff_msg(esp_ble_mesh_model_t *model,
esp_ble_mesh_server_recv_gen_onoff_set_t *set)
esp_ble_mesh_gen_onoff_srv_t *srv = model->user_data;
switch (ctx->recv_op)
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_GET:
esp_ble_mesh_server_model_send_msg(model, ctx,
ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_STATUS, sizeof(srv->state.onoff), &srv->state.onoff);
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET:
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET_UNACK:
if (set->op_en == false)
srv->state.onoff = set->onoff;
else
/* TODO: Delay and state transition */
if (ctx->recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET)
esp_ble_mesh_model_publish(model, ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_STATUS,
sizeof(srv->state.onoff), &srv->state.onoff, ROLE_NODE);
example_change_led_state(model, ctx, srv->state.onoff);
default:
static void example_ble_mesh_provisioning_cb(esp_ble_mesh_prov_cb_event_t event,
esp_ble_mesh_prov_cb_param_t *param)
switch (event)
case ESP_BLE_MESH_PROV_REGISTER_COMP_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_PROV_REGISTER_COMP_EVT, err_code %d", param->prov_register_comp.err_code);
case ESP_BLE_MESH_NODE_PROV_ENABLE_COMP_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_ENABLE_COMP_EVT, err_code %d", param->node_prov_enable_comp.err_code);
case ESP_BLE_MESH_NODE_PROV_LINK_OPEN_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_LINK_OPEN_EVT, bearer %s",
param->node_prov_link_open.bearer == ESP_BLE_MESH_PROV_ADV ? "PB-ADV" : "PB-GATT");
case ESP_BLE_MESH_NODE_PROV_LINK_CLOSE_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_LINK_CLOSE_EVT, bearer %s",
param->node_prov_link_close.bearer == ESP_BLE_MESH_PROV_ADV ? "PB-ADV" : "PB-GATT");
case ESP_BLE_MESH_NODE_PROV_COMPLETE_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_COMPLETE_EVT");
prov_complete(param->node_prov_complete.net_idx, param->node_prov_complete.addr,
param->node_prov_complete.flags, param->node_prov_complete.iv_index);
case ESP_BLE_MESH_NODE_PROV_RESET_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_RESET_EVT");
case ESP_BLE_MESH_NODE_SET_UNPROV_DEV_NAME_COMP_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_SET_UNPROV_DEV_NAME_COMP_EVT, err_code %d", param->node_set_unprov_dev_name_comp.err_code);
default:
static void example_ble_mesh_generic_server_cb(esp_ble_mesh_generic_server_cb_event_t event,
esp_ble_mesh_generic_server_cb_param_t *param)
esp_ble_mesh_gen_onoff_srv_t *srv;
ESP_LOGI(TAG, "event 0x%02x, opcode 0x%04x, src 0x%04x, dst 0x%04x",
event, param->ctx.recv_op, param->ctx.addr, param->ctx.recv_dst);
switch (event)
case ESP_BLE_MESH_GENERIC_SERVER_STATE_CHANGE_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_STATE_CHANGE_EVT");
if (param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET ||
param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET_UNACK)
ESP_LOGI(TAG, "onoff 0x%02x", param->value.state_change.onoff_set.onoff);
example_change_led_state(param->model, ¶m->ctx, param->value.state_change.onoff_set.onoff);
case ESP_BLE_MESH_GENERIC_SERVER_RECV_GET_MSG_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_RECV_GET_MSG_EVT");
if (param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_GET)
srv = param->model->user_data;
ESP_LOGI(TAG, "onoff 0x%02x", srv->state.onoff);
example_handle_gen_onoff_msg(param->model, ¶m->ctx, NULL);
case ESP_BLE_MESH_GENERIC_SERVER_RECV_SET_MSG_EVT:
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_RECV_SET_MSG_EVT");
ESP_LOGI(TAG, "onoff 0x%02x, tid 0x%02x", param->value.set.onoff.onoff, param->value.set.onoff.tid);
if (param->value.set.onoff.op_en)
ESP_LOGI(TAG, "trans_time 0x%02x, delay 0x%02x",
param->value.set.onoff.trans_time, param->value.set.onoff.delay);
example_handle_gen_onoff_msg(param->model, ¶m->ctx, ¶m->value.set.onoff);
default:
ESP_LOGE(TAG, "Unknown Generic Server event 0x%02x", event);
void example_ble_mesh_lighting_server_cb(esp_ble_mesh_lighting_server_cb_event_t event,
esp_ble_mesh_lighting_server_cb_param_t *param)
esp_ble_mesh_server_state_value_t state = {0};
uint16_t lightness;
switch (event)
case ESP_BLE_MESH_LIGHTING_SERVER_STATE_CHANGE_EVT:
switch (param->ctx.recv_op)
case ESP_BLE_MESH_MODEL_OP_LIGHT_LIGHTNESS_SET:
case ESP_BLE_MESH_MODEL_OP_LIGHT_LIGHTNESS_SET_UNACK:
/* Light Lightness Server Model - Primary Element */
ESP_LOGI(TAG, "lightness actual 0x%04x", param->value.state_change.lightness_set.lightness);
/* Update bound states */
lightness = param->value.state_change.lightness_set.lightness;
state.light_lightness_linear.lightness = convert_lightness_actual_to_linear(lightness);
esp_ble_mesh_server_model_update_state(lightness_server.model, ESP_BLE_MESH_LIGHT_LIGHTNESS_LINEAR_STATE, &state);
default:
ESP_LOGE(TAG, "Unknown Lighting Server event 0x%02x", event);
static void example_ble_mesh_config_server_cb(esp_ble_mesh_cfg_server_cb_event_t event,
esp_ble_mesh_cfg_server_cb_param_t *param)
if (event == ESP_BLE_MESH_CFG_SERVER_STATE_CHANGE_EVT)
case ESP_BLE_MESH_MODEL_OP_APP_KEY_ADD:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_APP_KEY_ADD");
ESP_LOGI(TAG, "net_idx 0x%04x, app_idx 0x%04x",
param->value.state_change.appkey_add.net_idx,
param->value.state_change.appkey_add.app_idx);
ESP_LOG_BUFFER_HEX("AppKey", param->value.state_change.appkey_add.app_key, 16);
case ESP_BLE_MESH_MODEL_OP_MODEL_APP_BIND:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_MODEL_APP_BIND");
ESP_LOGI(TAG, "elem_addr 0x%04x, app_idx 0x%04x, cid 0x%04x, mod_id 0x%04x",
param->value.state_change.mod_app_bind.element_addr,
param->value.state_change.mod_app_bind.app_idx,
param->value.state_change.mod_app_bind.company_id,
param->value.state_change.mod_app_bind.model_id);
case ESP_BLE_MESH_MODEL_OP_MODEL_SUB_ADD:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_MODEL_SUB_ADD");
ESP_LOGI(TAG, "elem_addr 0x%04x, sub_addr 0x%04x, cid 0x%04x, mod_id 0x%04x",
param->value.state_change.mod_sub_add.element_addr,
param->value.state_change.mod_sub_add.sub_addr,
param->value.state_change.mod_sub_add.company_id,
param->value.state_change.mod_sub_add.model_id);
default:
static esp_err_t ble_mesh_init(void)
esp_err_t err = ESP_OK;
esp_ble_mesh_register_prov_callback(example_ble_mesh_provisioning_cb);
esp_ble_mesh_register_config_server_callback(example_ble_mesh_config_server_cb);
esp_ble_mesh_register_generic_server_callback(example_ble_mesh_generic_server_cb);
esp_ble_mesh_register_lighting_server_callback(example_ble_mesh_lighting_server_cb);
err = esp_ble_mesh_init(&provision, &composition);
if (err != ESP_OK)
ESP_LOGE(TAG, "Failed to initialize mesh stack (err %d)", err);
return err;
err = esp_ble_mesh_node_prov_enable(ESP_BLE_MESH_PROV_ADV | ESP_BLE_MESH_PROV_GATT);
if (err != ESP_OK)
ESP_LOGE(TAG, "Failed to enable mesh node (err %d)", err);
return err;
ESP_LOGI(TAG, "BLE Mesh Node initialized");
board_led_operation(LED_G, LED_ON);
return err;
void app_main(void)
esp_err_t err;
ESP_LOGI(TAG, "Initializing...");
board_init();
err = nvs_flash_init();
if (err == ESP_ERR_NVS_NO_FREE_PAGES)
ESP_ERROR_CHECK(err);
err = bluetooth_init();
if (err)
ESP_LOGE(TAG, "esp32_bluetooth_init failed (err %d)", err);
return;
ble_mesh_get_dev_uuid(dev_uuid);
/* Initialize the Bluetooth Mesh Subsystem */
err = ble_mesh_init();
if (err)
ESP_LOGE(TAG, "Bluetooth mesh init failed (err %d)", err);
