gpio input voltage
neilmac1
gpio input voltage
Postby neilmac1 » Sun Jul 23, 2023 7:10 am
can some one tell me the max voltage of a esp32 input pin can take i have a lot of sensors that give out 5v logic high
and dont wont to overload the esp32 ?????
also am i right in that esp32 pins gpio are input only thanks for your time and help
Re: gpio input voltage
Postby Sprite » Sun Jul 23, 2023 10:37 am
As with most chips, the datasheet has that info. Section 4.3 gives a Vih of Vdd+0.3V, and given that generally the ESP32 is run at Vdd=3.3V, the maximum you can put on a pin is 3.6V. So no, the ESP32 is not compatible with 5V sensors and you need some sort of level converter.
Users browsing this forum: Amazon [Bot] and 2 guests
