Hello Friends, I have two ESP32 one is Wemos Lolin32 Lite and the other is a Wrover Module, I am using the SPIFFS function and in the Wemos Lolin32 Lite it works without problems but in the Wrover that has more memory it shows me the following error:
"E (466) SPIFFS: spiffs partition could not be found"
I have already used three Wrover modules and they all have the same problem, I could not find the s solution. Thanks in advance
ESP32 WROVER
Re: ESP32 WROVER
Somebody solved it here.
You can see this: https://esp32.com/viewtopic.php?t=6784
You can also see this tutorial. This is based on ESP8266 though. But it outlines the basic principle of Creating Webserver with ESP8266 using SPIFFS: https://www.theengineeringprojects.com/ ... piffs.html
Users browsing this forum: Bytespider and 9 guests
