ESP32S3 WiFi memory overwrite
in one of my projects I am experiencing a very strange behaviour when some device connects to the wifi in AP mode. To not attach a whole bunk of code I will try to explain in a simple matter.
I use a global pointer to a structure variable, where during the runtime at need memory is allocated. This variable is then used inside different functions. In one specific function most of the time the program crashes because the data has changed in the phase of connecting to the ESP AP. I use TCP/UDP, but for testing purposes it was disabled o just the wifi initialization is made.
To be sure this really happens a simple task was created which checks when the data has changed. The test scenario was.
1. Allocate memory
2. Call the function, set data
3. Idle
4. Connect to wifi with phone
So the "checking" function should print something just when point 2 reached. If you see the log bellow we see it has changed just before the first wifi system serial output has happen.
pItemList: 3fcd19a4 (Enter point 2)
menuEntry
ClearMenu
pItemList: f2500004 (Changed without control)
I (51134) wifi:new :<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (51135) wifi:station : 0e:78:62:a7:64:fe join, AID=1, bgn, 20
pItemList: 420000a4 (Changed without control)
*NULL
I (51345) wifi:<ba-add>idx:2 (ifx:1, 0e:78:62:a7:64:fe), tid:0, ssn:0, winSize:64
I (51544) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.1.2
I (51619) wifi:<ba-add>idx:3 (ifx:1, 0e:78:62:a7:64:fe), tid:7, ssn:2, winSize:64
pItemList: 3fcb79b4 (Changed without control)
pItemList: 17 (Changed without control)
I (52457) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.1.2
pItemList: 2000406 (Changed without control)
pItemList: 3fcd1a58 (Changed without control)
I was sure it is some of my problems, but the variable cant in my part of code not change. Also other tasks related to wifi are disabled to make sure it would not influence. Has someone any idea?
1. Allocate memory
3. Idle
menuEntry
ClearMenu
*NULL
MicroController
Re: ESP32S3 WiFi memory overwrite
No way of telling what the problem is without any of your code. The pointer itself may have gotten corrupted, the memory may have been inadvertently free'd somewhere ("use after free"), another pointer may cause erroneous writes to the wrong memory (invalid array index? use after free? invalid cast of a pointer?...), or a stack overflow may have happened w/o being detected.
Edit:
Edit:
"The data" = the global pointer?because the data has changed
Yes its a global pointer, which is used for a graphical menu handler. Therefore, it contains multiple information like, number of lines, prev./next menu, label pointers, etc. To attach the whole code wouldn't make sense.
But, this pointer is only changed on a event such as a button press. To make sure my code doesn't cause this problem I have:
1. Disabled all tasks which are related to wifi and performed only the AP initialization like this:
2. I entered the specific menu where the crash occurs and made sure no button will be pressed durring wifi connect
So the program crashed ONLY if connect to wifi and also only then the memory is overwriten (except of course if a button would be pressed). If the the phone will not connect everything works as expected.
wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL, NULL));
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler, NULL));
// Copy saved AP SSID and pass. setting to esp wifi structure
strcpy((char*)wifi_config_ap.ap.ssid, settings.wifi.SSID.value);
memset(wifi_config_ap.ap.password, 0, 64);
strcpy((char*)wifi_config_ap.ap.password, settings.wifi.password.value);
wifi_config_ap.ap.ssid_len = strlen((char*)wifi_config_ap.ap.ssid);
wifi_config_ap.ap.max_connection = 1;
wifi_config_ap.ap.channel = 0;
if (strlen((char*)wifi_config_ap.ap.password) == 0) {
wifi_config_ap.ap.authmode = WIFI_AUTH_OPEN;
wifi_config_ap.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK;
if (strlen((char*)wifi_config_ap.ap.ssid) == 0) {
strcpy((char*)wifi_config_ap.ap.ssid, "pico");
esp_wifi_set_mode(WIFI_MODE_AP);
esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config_ap);So the program crashed ONLY if connect to wifi and also only then the memory is overwriten (except of course if a button would be pressed). If the the phone will not connect everything works as expected.
you need to close in braces like (char*)(wifi_config_ap.ap.ssid), same with (char*)(wifi_config_ap.ap.password), etcYes its a global pointer, which is used for a graphical menu handler. Therefore, it contains multiple information like, number of lines, prev./next menu, label pointers, etc. To attach the whole code wouldn't make sense.
1. Disabled all tasks which are related to wifi and performed only the AP initialization like this:2. I entered the specific menu where the crash occurs and made sure no button will be pressed durring wifi connectCode: Select all
ESP_ERROR_CHECK(esp_netif_init()); wifi_event_group = xEventGroupCreate(); ESP_ERROR_CHECK(esp_event_loop_create_default()); ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL, NULL)); ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler, NULL)); // Copy saved AP SSID and pass. setting to esp wifi structure strcpy((char*)wifi_config_ap.ap.ssid, settings.wifi.SSID.value); memset(wifi_config_ap.ap.password, 0, 64); strcpy((char*)wifi_config_ap.ap.password, settings.wifi.password.value); wifi_config_ap.ap.ssid_len = strlen((char*)wifi_config_ap.ap.ssid); wifi_config_ap.ap.max_connection = 1; wifi_config_ap.ap.channel = 0; if (strlen((char*)wifi_config_ap.ap.password) == 0) { wifi_config_ap.ap.authmode = WIFI_AUTH_OPEN; } else { wifi_config_ap.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK; } if (strlen((char*)wifi_config_ap.ap.ssid) == 0) { strcpy((char*)wifi_config_ap.ap.ssid, "pico"); } esp_wifi_set_mode(WIFI_MODE_AP); esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config_ap);
I wouldn't agree with you that this is really needed in C.
MicroController
The C specification doesn't agree either.I wouldn't agree with you that this is really needed in C.
MicroController
Ok, so it's the pointer which is overwritten, not the data it points to.Yes its a global pointer,
Maybe not. ButTo attach the whole code wouldn't make sense.
indicates that it is inadvertently/erroneously overwritten by some other code (see my first answer) possibly completely unrelated to where you intentionally operate on the pointer variable. So, not seeing the code which is actually at fault, there's not much help we can provide beyond recommending to go looking for any invalid memory accesses or pointer handling across your code base.this pointer is only changed on a event such as a button press.
One option to trace this down: can you attach a debugger via (USB-serial-)JTAG and set a watchpoint on that pointer?
Good idea. I have tried it out. The program already crashes before even the watchpoint can be cached. The result is as followed:One option to trace this down: can you attach a debugger via (USB-serial-)JTAG and set a watchpoint on that pointer?
Break at address "0x400570ee" with no debug information available, or outside of program code.
In the terminal the last line which was printet is:
I (145012) wifi:new :<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
Users browsing this forum: Applebot, ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot, Semrush [Bot], YisouSpider and 5 guests
