Example Wifi FTM Issues
JJ8428
Postby JJ8428 » Fri Jul 28, 2023 3:14 am
I currently hold 2 ESP32 S2 Dev Modules. I have been able to connect them to my computer with the proper cords, drivers, and etc. I also have the latest necessary packages installed in the Arduino IDE (Specifically, esp32 by espressif (Version 2.0.11).
https://github.com/espressif/arduino-es ... mples/FTM/
On one board, I have the Wifi FTM responder loaded and it works fine.
On the other board, I have the Wifi FTM initiator loaded and it seems to be able to connect to the Wifi FTM responder. It prints out a stream of text in the Serial Monitor similar to below for a solid 5 seconds before it disconnects from the FTM responder.
FTM Estimate: Distance: 1.16 m, Return Time: 8 ns
FTM Estimate: Distance: 1.13 m, Return Time: 8 ns
FTM Estimate: Distance: 1.26 m, Return Time: 9 ns
FTM Estimate: Distance: 1.00 m, Return Time: 9 ns
Has anyone else dealt with this issue before?
Users browsing this forum: ChatGPT-User, Google [Bot], Qwantbot and 1 guest
