Tagging heap assigned to non-PSRAM (low) memory?
tschak909
Postby tschak909 » Sun Jul 30, 2023 2:44 pm
Hi everyone.
I am in the midst of debugging a very complex set of memory leaks in #FujiNet, around the Network sub-device.
The Heap tracer is very useful, however, I do wish I could actually get function names, instead of function pointers, in the dump, is there a way to facilitate that?
Also, is there a way to figure out which portion of memory a given allocator is using? I need to see if something I'm doing in my code is causing an allocation to the low memory, instead of the PSRAM.
-Thom
igrr
Re: Tagging heap assigned to non-PSRAM (low) memory?
Postby igrr » Sun Jul 30, 2023 6:57 pm
Hi Thom,
Function pointers should be automatically decoded on the host side if you use IDF Monitor (https://docs.espressif.com/projects/esp ... s-decoding).
Doing this in the application itself is not viable, unfortunately.
I'm not 100% sure what you mean by "given memory allocator" but perhaps heap_caps_dump or heap_caps_dump_all helps? (https://docs.espressif.com/projects/esp ... _dump_allv)
MicroController
Postby MicroController » Tue Aug 01, 2023 3:45 pm
The heap trace dump should say "Internal" or "PSRAM" respectively for each entry...
Not sure what "allocator" you are referring to.
Users browsing this forum: Applebot, ChatGPT-User and 1 guest
