gpio_intr_enable() unnecessary?
jhennrich
Postby jhennrich » Thu Aug 03, 2023 2:32 pm
1: I just wrote a minimal code example to enable a rising-edge Interrupt for a GPIO using the IDF 5.1. The code works and the Interrupt is detected, however I noticed that calling the function "gpio_intr_enable()" is completely unnecessary:
gpio_num_t gpio_num = GPIO_NUM_0;
// [set gpio_num as input, enable pullups etc.... ]
gpio_set_intr_type(gpio_num, GPIO_INTR_POSEDGE);
gpio_intr_enable(gpio_num);
gpio_install_isr_service(0);
gpio_isr_handler_add(gpio_num, gpio_isr_handler, (void*) gpio_num);
When I comment out the line "gpio_intr_enable(gpio_num)" the interrupt is still detected.
Another thing I noticed: I can even disable the interrupt using "gpio_intr_disable(gpio_num)" and the Interrupt is still detected:
gpio_intr_disable(gpio_num); // DISABLE Interrupt, but still works!
Can anyone explain this?
2: I noticed that there are multiple ways to configure the interrupt type for a GPIO:
- esp_err_t gpio_config(const gpio_config_t *pGPIOConfig) --> "gpio_config_t" has a member "gpio_int_type_t intr_type"
- esp_err_t gpio_set_intr_type(gpio_num_t gpio_num, gpio_int_type_t intr_type) --> sets intr_type
This seems redundant and I am wondering if one of the functions is intended to be deprecated? Which one should be used?
Best regards
MicroController
Re: gpio_intr_enable() unnecessary?
Postby MicroController » Fri Aug 04, 2023 10:09 pm
gpio_isr_handler_add(...) implicitly enables the corresponding interrupt.
gpio_config(...) is used for convenient initialization of GPIO pins, including possibly interrupt settings.
gpio_set_intr_type(...) can be used to (later) modify only the interrupt settings of a GPIO pin w/o having to completely reconfigure the pin via gpio_config(...), potentially causing glitches or the like. If you look at gpio_config()'s code, you'll see that it does a whole lot of stuff for us, which I'm glad I don't have to implement myself, but which I don't necessarily want to run repeatedly each time I modify a single setting of a GPIO.
Users browsing this forum: Bing [Bot], Bytespider, DuckDuckGo [Bot] and 2 guests
