Hello Espressif Community,
I have two questions related to the PWM hardware of ESP32:
1. By the documentation of the LEDC library, there are 4 timers and 16 PWM channels in ESP32. I would like to ask if all of the 4 timers are ticking at 80 MHz (assume all prescaler is 1).
2. I know that the frequency and resolution of a specific PWM channel are inversely-proportioned. However, I cannot find an exact mathematical formula to describe their relation. For example, if I set the frequency to be 10 kHz, what is the maximum bit count of resolution? How do I calculate that?
Thank you very much for your help.
PWM of ESP32
MicroController
Re: PWM of ESP32
TRM, §14.2.1:1. By the documentation of the LEDC library, there are 4 timers and 16 PWM channels in ESP32. I would like to ask if all of the 4 timers are ticking at 80 MHz (assume all prescaler is 1).
"the LED_PWM controller contains eight high-speed and eight low-speed channels. There are four high-speed clock modules for
the high-speed channels, from which one h_timerx can be selected. There are also four low-speed clock modules
for the low-speed channels, from which one l_timerx can be selected."
§14.2.2:
"Where the high-speed timer clock source can be clocked from REF_TICK or APB_CLK, the low-speed timers
are sourced from either REF_TICK or SLOW_CLOCK. The SLOW_CLOCK source can be either APB_CLK
(80 MHz) or 8 MHz,..."
If F[clk] is the timer's clock and F[pwm] the PWM frequency and r is the PWM resolution, the following holds:2. I know that the frequency and resolution of a specific PWM channel are inversely-proportioned. However, I cannot find an exact mathematical formula to describe their relation. For example, if I set the frequency to be 10 kHz, what is the maximum bit count of resolution? How do I calculate that?
r = 2 ^ bitcount ("two to the power of bitcount", or in C: 1<<bitcount)
F[pwm] = F[clk] / r = F[clk] / (2 ^ bitcount)
For given F[clk] and F[pwm] the theoretical maximum resolution is
r = F[clk] / F[pwm]
The required bit count is the log2 of the theoretical resolution; ex.:
F[clk] = 80'000'000Hz
F[pwm] = 10'000Hz
r = 8000
log2(r) ~ 12.97... bits
So for F[pwm] not less than 10kHz, you need a bit count not greater than 12.97..., i.e. the maximum bit count value permissible to achieve (at least) the given F[pwm] is 12 in the example.
The actual resolution you get is then 2^12 = 4096 steps, the actual F[pwm] is 80'000'000Hz/4096 ~ 19.5kHz.
If you chose 13 bits (8192 steps), F[pwm] would top out at ~9.77kHz, not quite reaching 10kHz.
Works the other way around too: If you need a resolution of not less than r=5000 steps you get log2(5000) ~ 12.29... bits and you'll need a bit count of not less than 12.29..., so at least 13 (i.e. 8192 steps).
Users browsing this forum: Google [Bot], Semrush [Bot] and 3 guests
