Sending or Receiving data over UDP/TCP
Vineethad
Postby Vineethad » Wed Aug 16, 2023 6:55 am
I am using ESP32-C6 module and the tool is ESP IDF with VSCode.
How to send or receive data over TCP/UDP protocol ?
Please find me the solution.
Thanks.
MicroController
Re: Sending or Receiving data over UDP/TCP
Postby MicroController » Wed Aug 16, 2023 11:38 am
Vineethad
Postby Vineethad » Thu Aug 17, 2023 6:29 am
Hi Everyone,
I am trying with UDP Client example but it is unable to connect to the host. It's showing like "connecting to host...." and "waiting for IP...." . Why it is showing like this ?
Actually I am new to this ESP32 WIFI modules so please help me...
Thanks in Advance.
MicroController
Postby MicroController » Thu Aug 17, 2023 10:29 am
Post the actual log output you get.
Vineethad
Postby Vineethad » Thu Aug 17, 2023 11:23 am
Actual log output is below attached file.
Screenshot 2023-08-17 115121.png (72.7 KiB) Viewed 6174 times
MicroController
Postby MicroController » Sat Aug 19, 2023 9:22 am
Apparently, the ESP already fails to connect to your WiFi. Double-check that the SSID and password are correct; then check that your WiFi is set to allow the new device to connect. Try to improve the WiFi signal by moving the ESP closer to the access point.
Vineethad
Postby Vineethad » Mon Aug 21, 2023 5:21 am
I checked the SSID and Password of my WiFi network is correct. I followed the all the instructions as you said but I am still getting the same result.
Thank you.
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Mon Aug 21, 2023 8:17 am
The example UDP_Client working fine with ESP32-C6 module. Make sure your password is not less than 8 character.
I (631) wifi:mode : sta (40:4c:ca:41:ca:60)
I (631) wifi:enable tsf
I (631) example_connect: Connecting to Uchi...
I (641) example_connect: Waiting for IP(s)
I (3041) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1
I (3041) wifi:(connect)dot11_authmode:0x3, pairwise_cipher:0x3, group_cipher:0x3
I (3821) wifi:state: init -> auth (b0)
I (3821) wifi:state: auth -> assoc (0)
I (3831) wifi:Extended Capabilities length:8, subtype:0x10, b0:4e:26:03:37:1f, Operating mode notification Support
I (3831) wifi:state: assoc -> run (10)
I (3831) wifi:(trc)phytype:CBW20-SGI, snr:60, maxRate:144, highestRateIdx:0
I (3841) wifi:(trc)rate(S-MCS7, schedIdx:0), ampdu(rate:S-MCS7, schedIdx(0, stop:8)), snr:60, ampduState:wait operational
I (3851) wifi:ifidx:0, rssi:-38, nf:-98, phytype(0x3, CBW20-SGI), phymode(0x3, 11bgn), max_rate:1440, he:0
I (3861) wifi:max ampdu length exponent:3(65535 bytes), mmss:6(8 us)
W (3861) wifi:<ba-add>idx:0, ifx:0, tid:0, TAHI:0x1001f37, TALO:0x3264eb0, (ssn:0, win:64, cur_ssn:0), CONF:0xc0000005
I (3891) wifi:(extcap)mbssid:0, enhanced_mbssid_advertise:0, complete_nontxbssid_profiles:0
I (3891) wifi:connected with Uchi, aid = 3, channel 1, BW20, bssid = b0:4e:26:03:37:1f
I (3901) wifi:cipher(pairwise:0x3, group:0x3), pmf:0, security:WPA2-PSK, phy:11bgn, rssi:-38
I (3901) wifi:pm start, type: 1, itwt_start:0
Vineethad
Postby Vineethad » Mon Aug 21, 2023 10:55 am
My password is more than 8 character. But still I am getting same .
Users browsing this forum: Bytespider, PerplexityBot, Qwantbot, YisouSpider and 7 guests
