Thank you
Re: ESP32-S3 SPI pin remapping
Normally you can use any (not otherwise occupied) GPIO, just pass them to the initialization function. Using the GPIO matrix as such adds a slight delay to the signals, but unless you run SPI at its absolute maximum speed, that likely doesn't matter.
downisquad
Dear jiqz,Thank you, I will test this out and provide an update
could you already test this out?
Could you be so kind and share your code?
Thanks!
downisquad
Users browsing this forum: ChatGPT-User, PetalBot and 1 guest
