Page 1 of 2
touchRead breaking analogWrite?
Posted: Tue Aug 29, 2023 3:58 pm
by zmaker
Some context for my issue, I'm designing a custom flashlight and have already received the prototype pcb. I thought I'd try to add capacitive touch but now 2/5 of the lights don't work. The lights DO work when I run a code that simply turns each one on and then off to test the leds. However, when I add touchRead(T0) the leds on gpio pins 14 and 15 stop working while the leds on pins 16, 17, and 18 continue to function as normal.
I'm using touchRead(T0) to reach the touch input, and have tried digitalWrite, analogWrite, and ledcWrite which all work without touchRead but fail when I add it back.
I have done a little bit of reading and the things that jump out are the following. If they are in fact issues, I haven't found a way around them.
1) Slot 1 of SDIO pins, which includes pins 14 and 15, is multiplexed with touch... though I don't really know how that could cause an issue
2) Touch0 is on an ADC2 pin, pins 14 and 15 are also on ADC2 pins... again, not sure why this would cause an issue though.
Code: Untitled.txt Select all
//#include <WiFi.h>
#include "driver/adc.h"
#define LEDwhite 14
#define LED1 15
#define LED2 16
#define LED3 17
#define LED4 18
byte brightness;
int state = 0;
// TESTING
// the number of the LED pin
const int ledPin1 = 15;
const int ledPin2 = 16; // 16 corresponds to GPIO16
const int ledPin3 = 17;
const int ledPin4 = 18;
// setting PWM properties
const int freq = 5000;
const int ledChannel = 0;
const int resolution = 8;
// the setup routine runs once when you press reset:
void setup() {
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
//Serial.begin(115200);
//adc_power_release(); // disable ADC
//pinMode(LEDwhite, OUTPUT);
//pinMode(LED1, OUTPUT);
//pinMode(LED2, OUTPUT);
ledcSetup(ledChannel, freq, resolution);
ledcAttachPin(ledPin1, ledChannel);
ledcAttachPin(ledPin2, ledChannel);
//ledcAttachPin(ledPin3, ledChannel);
//ledcAttachPin(ledPin4, ledChannel);
//pinMode(LED3, OUTPUT);
//pinMode(LED4, OUTPUT);
//digitalWrite(LEDwhite, LOW);
//digitalWrite(LED1, LOW);
//digitalWrite(LED2, LOW);
//digitalWrite(LED3, LOW);
//digitalWrite(LED4, LOW);
brightness = 100;
// the loop routine runs over and over again forever:
void loop() {
//Serial.print("\nDefault ESP32 MAC Address: ");
//Serial.println(WiFi.macAddress());
// Various Tests
capacativeTouchTest();
//blinkTest();
//printButtonStates();
void capacativeTouchTest() {
//void adc_power_on(void);
//delay(10);
Button1 = touchRead(T0); // get value of Touch 0 pin = GPIO 4... can swap with 24?
//void adc_power_off(void);
//delay(10);
if (Button1 < 30){
ledcWrite(ledChannel, 50);
Serial.println("ON");
delay(10);
//turnWhiteOn();
else {
ledcWrite(ledChannel, 0);
Serial.println("OFF");
void brightnessTest() {
delay(500); // delay in between reads for stability
if (brightness < 50) {
brightness = brightness + 20;
} else {
brightness = 0;
analogWrite(LEDwhite, brightness);
Serial.print("Brightness: ");
Serial.println(brightness);
void turnWhiteOn(){
analogWrite(LEDwhite, 50);
delay(50);
void blinkTest() {
delay(250);
turnWhiteOn();
delay(250);
analogWrite(LEDwhite, LOW);
analogWrite(LED1, 50);
delay(250);
analogWrite(LED1, LOW);
analogWrite(LED2, 50);
delay(250);
analogWrite(LED2, LOW);
analogWrite(LED3, 50);
delay(250);
analogWrite(LED3, LOW);
analogWrite(LED4, 50);
delay(250);
analogWrite(LED4, LOW);
delay(5000);
Re: touchRead breaking analogWrite?
Posted: Thu Aug 31, 2023 6:34 pm
by lbernstone
I recommend against using T0 naming (A0, D0, etc). Use the actual pin numbers. That way you know exactly which pin you are talking about.
ADC2 is unavailable when WiFi is running. I don't know whether this affects the touch peripheral, but you can certainly test without WiFi and see if that is what is affecting it.
Posted: Thu Aug 31, 2023 6:38 pm
by zmaker
Wi-Fi was commented out and not being run while testing
Posted: Tue Sep 19, 2023 4:42 am
by zmaker
Good, I don't want wifi interfering.
Posted: Wed Sep 20, 2023 1:23 am
by lbernstone
Does everything work if you set an interrupt instead of a direct read?
https://github.com/espressif/arduino-es ... errupt.ino
Posted: Wed Sep 20, 2023 1:46 am
by zmaker
I did try this, great suggestion. It did not work either, I even tried detaching the interrupt before writing the led pwm. With both cases, I had the same issues as before where it worked on 3/5 of the led pins and did not with 2 of them.
Posted: Wed Sep 20, 2023 3:26 am
by lbernstone
Your example is ... confused. Can you reproduce the issue with this code?
// TESTING
const int LEDwhite = 14;
void setup() {
  Serial.begin(9600);
void loop() {
  analogWrite(LEDwhite, HIGH);
  delay(1000);
  ledcWrite(ledChannel, 128);
  delay(1000);
  Serial.printf("touchRead: %d\n", touchRead(4));
  delay(5000);
Posted: Thu Sep 21, 2023 1:18 am
by zmaker
I slightly changed the code to the below (just to make the timing go quicker).
In the first test I ran the exact code below, and after the first run, only 3/5 lights came on (this is after the touchRead(4) ran)
In the second test, the only thing I changed was commenting out the print line... then all 5 lights continuously toggled
// TESTING
void setup() {
  Serial.begin(9600);
void loop() {
  delay(1000);
  delay(1000);
  Serial.printf("touchRead: %d\n", touchRead(4)); //DISABLED THIS FOR TEST 2
  delay(500);
Posted: Thu Sep 21, 2023 2:15 am
by lbernstone
I'm unable to reproduce. If you are driving those LEDs through the esp32, then I would suggest a power issue. I have run many LED projects using the esp32 (and variants), and have not encountered this, although I generally prefer a button over capacitive.
Posted: Tue Oct 03, 2023 7:14 am
by zmaker
Do you know if there is a way to completely "turn off" the capacitive touch function? I have found a bunch of article online, and read though tons of forums to no avail
I even tried running the touchRead() on a separate core, but experienced the same loss in function
