Hi @Everyone
I recently started using ESP32.
I'm using Arduino IDE (2.1.1) with ESP32 (2.0.11) installed.
I would like you to help me.
I'm using ESP32 on the client.
When connecting to a BLE device, the BLE error "E (33524) BT_APPL: earlier enc was not done for same device" occurs.
I would like to know about the following.
the cause of the error
How to solve the erro
"BT_APPL: earlier enc was not done for same device" Cause and solution
S-Yamamoto
- Err.PNG (2.29 KiB) Viewed 5296 times
S-Yamamoto
Re: "BT_APPL: earlier enc was not done for same device" Cause and solution
Hi @Everyone
I found where the "E (33524) BT_APPL: No previous enc was run for the same device" occurs.
The issue occurs when connecting to the BLE device in client mode ("pClient = BLEDevice::createClient()") after running "pServer = BLEDevice::createServer()" for ESP32.
Running "pServer->disconnect(pServer->getConnId())" enables client mode, and server and client are not used at the same time.
I need to use BLE server and client on one ESP32.
I would like to know about:
1) Error meaning
2) How to resolve the error
1) Error meaning
S-Yamamoto
Hi @Everyone
Help me.
This issue occurs when running [1],[2] simultaneously on ESP32 and connecting to a BLE device in client mode ('pClient = BLEDevice::createClient()').
[1]pServer = BLEDevice::createServer()
[2]BLEDevice::setEncryptionLevel(ESP_BLE_SEC_ENCRYPT);
You need to use BLE server and client on one ESP32.
I would like to know if "E (33524) BT_APPL: No previous enc has been executed for the same device" is an error or a warning.
Help me.
S-Yamamoto
Hi @Everyone
I will report it.
The solution for "E (33524) BT_APPL: No previous enc was run for the same device" was the following steps:
[Step 1] pServer = BLEDevice::createServer()
[Step 2] Initialize BLE with BLEDevice::init() after BLEDevice::deinit(false)
[Step 3] pClient = BLEDevice::createClient();
E (33524) BT_APPL: No previous enc run for the same device no longer occurs.
I think the reason is that you don't create the server and client at the same time.
I will report it.
DynamicWhiteHat
Hello. I am having the same issue. What library are you using and do you still have the code you used?
Hi where do you deinit and init exactly? Could you share the portion of relevant code? Thanks
Users browsing this forum: Amazon [Bot], Barkrowler, Bing [Bot], ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot and 1 guest
