I am running the example https://github.com/espressif/esp-idf/tr ... s_rw_value on an ESP32.
When I use the default NVS storage (partition: "nvs") the code works as expected. When I try to use a custom partition, the device runs into the error ESP_ERR_NVS_PART_NOT_FOUND.
I would appreciate any help understanding what step(s) I have missed to get this functioning.
I have made the following changes to the example:
1. Custom name is 'nvsa' and I am using the function nvs_flash_init_partition() instead of nvs_flash_init.
const char* NVS_PARTITION_NAME = "nvsa";
// Initialize NVS
// esp_err_t err = nvs_flash_init();
esp_err_t err = nvs_flash_init_partition(NVS_PARTITION_NAME);Code: Select all
# ESP-IDF Partition Table
nvsa, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1M,I can verify that the partition binary is indeed created:
Partition table binary generated. Contents:
nvsa,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
*******************************************************************************The output I get is:
I (328) app_start: Starting scheduler on CPU0
I (332) app_start: Starting scheduler on CPU1
I (332) main_task: Started on CPU0
I (342) main_task: Calling app_main()
Opening Non-Volatile Storage (NVS) handle... Error (ESP_ERR_NVS_PART_NOT_FOUND) opening NVS handle!Finally, if I change the char array NVS_PARTITION_NAME to just 'nvs' (and update the partition table), it functions properly. I perform a flash erase between changes to partitions.csv and a clean build before flashing.
Any help is much appreciated!
I have further verified that the partition indeed exists (and I have tried using the partition pointer to initialize it), but still no success:
void app_main(void)
const char *NVS_PARTITION_NAME = "nvsa";
const esp_partition_t *partitionNvs = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_NVS, NVS_PARTITION_NAME);
if (partitionNvs == NULL)
ESP_LOGI(TAG, "NVS Partition \"%s\" not found", NVS_PARTITION_NAME);
else
ESP_LOGI(TAG, "NVS Partition \"%s\" found", NVS_PARTITION_NAME);
// Initialize NVS
// esp_err_t err = nvs_flash_init_partition(NVS_PARTITION_NAME);
esp_err_t err = nvs_flash_init_partition_ptr(partitionNvs);
if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND)
// NVS partition was truncated and needs to be erased
// Retry nvs_flash_init
ESP_ERROR_CHECK(err);Code: Select all
I (0) cpu_start: App cpu up.
I (221) cpu_start: Pro cpu start user code
I (221) cpu_start: cpu freq: 160000000 Hz
I (221) cpu_start: Application information:
I (226) cpu_start: Project name: nvs-c-storage
I (231) cpu_start: App version: 1
I (235) cpu_start: Compile time: Sep 7 2023 09:09:17
I (242) cpu_start: ELF file SHA256: 16f9ba6a86602b46...
I (248) cpu_start: ESP-IDF: v5.1-dirty
I (253) cpu_start: Min chip rev: v0.0
I (257) cpu_start: Max chip rev: v3.99
I (262) cpu_start: Chip rev: v3.1
I (267) heap_init: Initializing. RAM available for dynamic allocation:
I (274) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (280) heap_init: At 3FFB29D0 len 0002D630 (181 KiB): DRAM
I (287) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (293) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (299) heap_init: At 4008C688 len 00013978 (78 KiB): IRAM
I (307) spi_flash: detected chip: generic
I (310) spi_flash: flash io: dio
W (314) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (342) NVS-Storage-Example: NVS Partition "nvsa" found
Restarting in 4 seconds...
Restarting in 3 seconds...
Restarting in 2 seconds...
Restarting in 1 seconds...
Restarting in 0 seconds...
Restarting now.
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
