Connect stepper to Arduino/ESP32
Kapoue
Postby Kapoue » Tue Sep 12, 2023 10:56 am
I am complete newbie in electronic. I have suceeded to connect my stepper motor to the DM542T stepper driver and to an arduino UNO like this:
So now I am trying to use my ESP-32 and I have connected like this. But of course if I am here it is because it doesn't work :(
Here is the pin diagram provided by Az-Delivery:
As I will also connect a screen I would like to use only the free pin left:
I have use the exact same program on both except that I have modify the PIN_DIR and PIN_PUL to adapt the the correct pins I have used.
#include <Arduino.h>
#include "StepperMotor.h"
// Define pins for the motor
const int dirPin = 8;  // DIR+
const int stepPin = 9; // PUL
// Create an instance of the StepperMotor class
StepperMotor myStepper(dirPin, stepPin);
  // No need for setup here, everything is handled in the class constructor
  // Rotate the motor 1000 steps in one direction
  myStepper.moveStepperTo(1000);
  delay(1000); // Wait for one second
  // Rotate the motor 1000 steps in the other direction
  myStepper.moveStepperTo(0);
#ifndef STEPPER_MOTOR_H
#define STEPPER_MOTOR_H
#include <AccelStepper.h>
class StepperMotor {
  private:
    AccelStepper stepper;
    const int dirPin;
    const int stepPin;
  public:
    StepperMotor(int dirPin, int stepPin);
    void moveStepperTo(int position);
#endif // STEPPER_MOTOR_H
Did I missed something?
Regards,
lbernstone
Re: Connect stepper to Arduino/ESP32
Postby lbernstone » Wed Sep 13, 2023 4:43 pm
esp32 gpio runs at 3v3. If the stepper driver needs 5v signals, you will need a voltage shifter.
Users browsing this forum: ChatGPT-User, PetalBot, Semrush [Bot] and 4 guests
