Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Error Esp32
Xelbor
Postby Xelbor » Fri Sep 15, 2023 5:09 am
I'm trying to implement speech recognition on a max9814 microphone module. I found the code in the article, but it was written for Arduino Nano. I tried to port the code to Esp32, but I have little experience in this matter, and I studied some points in ChatGpt. However, I eventually ran into this error:
Core  1 register dump:
PC      : 0x400861f4  PS      : 0x00060c30  A0      : 0x800d16bd  A1      : 0x3ffc5450
A2      : 0x3ffc546e  A3      : 0x0000017a  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x800d1681  A9      : 0x3ffc5310
A10     : 0x3ffc546e  A11     : 0x0000000d  A12     : 0x00000001  A13     : 0x00002710
A14     : 0x3ffc1d54  A15     : 0xff000000  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000017a  LBEG    : 0x400d15f1  LEND    : 0x400d1622  LCOUNT  : 0x00000000
Backtrace: 0x400861f1:0x3ffc5450 0x400d16ba:0x3ffc5460 0x400d1851:0x3ffc54b0 0x400d1971:0x3ffc54d0 0x400d25e1:0x3ffc54f0
ELF file SHA256: 462eb524cea7298d
Rebooting...
And after that the error repeats.
Program code:
// Copyright 2021 Peter Balch
//   распознавание слов
//   подлежит GNU General Public License
#include <Arduino.h>
#include "driver/adc.h"
#include "Coeffs.h"
#include "Templates.h"
// Defines, constants and Typedefs
// Пины
const int AUDIO_IN = 35; // Используйте соответствующий пин ADC на ESP32
// Глобальные константы
const byte SegmentSize = 50; // в миллисекундах
const byte hyster = 2;
const byte thresh = 100;
// Глобальные переменные
int CurBandData[nSegments][nBand + 1]; // текущие данные полосы
bool bAnalyse = true;
// GetSerial
byte GetSerial() {
  while (Serial.available() == 0);
  return Serial.read();
// PollBands
bool PollBands(bool init)
  bool IsPos, Collecting;
  static unsigned long prevTime;
  byte band, seg, val1, val2, i;
  const byte hyster = 20;
  static int zero = 500;
  static byte curSegment = 255;
  long val;
  word zcr;
  static int valmax[10];
  static int pd[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
  static int ppd[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
  static int ppval = 0;
  static int pval = 0;
  if (init)
    memset(pd, 0, sizeof(pd));
    memset(ppd, 0, sizeof(ppd));
    memset(CurBandData, 0, sizeof(CurBandData));
    pval =  0;
    ppval =  0;
    return false;
  val = 0;
  IsPos = true;
  Collecting = false;
  int n = 0;
  for (curSegment = 0; curSegment < nSegments; curSegment++) {
    zcr = 0;
    prevTime = 0;
    memset(valmax, 0, sizeof(valmax));
    prevTime = millis();
    while (millis() - prevTime < SegmentSize)
      //    val = analogRead(AUDIO_IN);
      val1 = analogRead(AUDIO_IN);
      val2 = val1 >> 8;
      val1 &= 0xFF;
      val = val1 + (val2 << 8);
      if (val < zero)
        zero--;
      else
        zero++;
      val = val - zero;
      if (!Collecting) {
        if (abs(val) > thresh)
          Collecting = true; else
          return false;
      if (IsPos)
        if (val < -hyster)
          IsPos = false;
          zcr++;
        if (val > +hyster)
          IsPos = true;
          zcr++;
      ppval = pval;
      pval = val;
      for (band = 0; band < nBand; band++)
        int L1, L2;
        L1 = ((-(filt_b1[band]) * pd[band] - filt_b2[band] * ppd[band]) >> 16) + val;
        L2 = (filt_a0[band] * L1 - filt_a0[band] * ppd[band]) >> 16;
        ppd[band] = pd[band];
        pd[band] = L1;
        if (abs(L2) > valmax[band])
          valmax[band]++;
      CurBandData[curSegment][band + 1] = valmax[band];
    CurBandData[curSegment][0] = zcr;
  if (Collecting) {
    Serial.println("a");
    SendUtterance(CurBandData);
    if (bAnalyse)
      AnalyseUtterance(CurBandData);
  return Collecting;
// AnalyseUtterance
void AnalyseUtterance(int Utterance[nSegments][nBand+1]) {
  int i,dist;
  char buffer[30];
  i = FindBestUtterance(Utterance,&dist);
  strcpy_P(buffer, (char *)pgm_read_word(&(sUtterances[i])));
  Serial.println(i);
  Serial.println(buffer);
// PrintCurBandData
void PrintCurBandData(void)
  byte seg, band;
  for (seg = 0; seg < nSegments; seg++) {
    for (band = 0; band <= nBand; band++) {
      Serial.print(CurBandData[seg][band]);
      Serial.print(" ");
    Serial.println("");
// SendUtterance
void SendUtterance(int Utterance[nSegments][nBand+1])
  byte seg,band;
      Serial.print(Utterance[seg][band]);
      Serial.print(" ");
    Serial.println("");
// ShiftedDistance
//   distance from Utterance shifted by shift
//   to Templates[TemplateUtt]
int ShiftedDistance(int Utterance[nSegments][nBand+1], byte TemplateUtt, int8_t shift){
  byte band,seg,importance;
  int aUtterance[nSegments][nBand+1];
  int Dist,aMean,aSD;
  ShiftUtterance(Utterance, aUtterance, shift);
  Dist = 0;
    if (seg == 0)
      importance = 2; else
      importance = 1;
      aMean = pgm_read_word(&Templates[TemplateUtt][seg][band].mean);
      aSD = pgm_read_word(&Templates[TemplateUtt][seg][band].sd);
      Dist = constrain(Dist+importance*abs(((long)aUtterance[seg][band])-aMean)*1000 / (50+aSD),-10000,+10000);
  return Dist;
// ShiftUtterance
//   shift an utterance by shift/SubShifts
void ShiftUtterance(int utSource[nSegments][nBand+1], int utDest[nSegments][nBand+1], int shift) {
  int8_t i,j,k,n;
  int m;
  byte seg,band;
  if (shift == 0) {
        utDest[seg][band] = utSource[seg][band];
      n = SubShifts*(nSegments-1);
      i = shift*(nSegments-1);
      j = -i / (SubShifts*(nSegments-1));
      i = abs(i) % ((nSegments-1)*SubShifts);
      if (shift < 0)
        k = j+1; else
        k = j-1;
        if ((seg+j >= 0) && (seg+j < nSegments))
          m = utSource[seg+j][band]*((nSegments-1)*SubShifts-i) / n; else
          m = 0;
        if ((seg+k >= 0) && (seg+k < nSegments))
          m = m+utSource[seg+k][band]*i / n;
        utDest[seg][band] = m;
  NormaliseUtterance(utDest);
// NormaliseUtterance
void NormaliseUtterance(int Utterance[nSegments][nBand+1]) {
  byte seg,band;
  long SegmentTotal,i;
  SegmentTotal = 0;
      SegmentTotal += Utterance[seg][band];
  SegmentTotal = max(SegmentTotal, static_cast<long>(1));
  i = 50*nSegments*nBand;
      Utterance[seg][band] = (i*Utterance[seg][band]) / SegmentTotal;
// FindBestShift
int FindBestShift(int Utterance[nSegments][nBand+1], int TemplateUtt) {
  int dist,BestShift,BestShiftDist,shift;
  BestShiftDist = 0x7FFF;
  for (shift = -MaxShift; shift <= MaxShift; shift++) {
    dist = ShiftedDistance(Utterance,TemplateUtt,shift);
    if (dist < BestShiftDist) {
      BestShiftDist = dist;
      BestShift = shift;
  return BestShift;
// FindBestUtterance
//   which template best fits the utterance
int FindBestUtterance(int Utterance[nSegments][nBand+1], int *BestDist) {
  int dist,BestUttDist,shiftDist;
  int BestUtt,shift,TemplateUtt;
  BestUtt = 0;
  *BestDist = 0;
  BestUttDist = 0x7FFF;
  for (TemplateUtt = 0; TemplateUtt < nUtterances; TemplateUtt++) {
    shift = FindBestShift(Utterance,TemplateUtt);
    shiftDist = ShiftedDistance(Utterance,TemplateUtt,shift);
    if (shiftDist < BestUttDist) {
      BestUttDist = shiftDist;
      BestUtt = TemplateUtt;
      *BestDist = BestUttDist;
  return BestUtt;
// CheckSerial
void CheckSerial(void)
  byte seg,band,i,j;
  static int Utterance[nSegments][nBand+1];
  if (Serial.available() > 0) {
    switch (GetSerial()) {
      case 'u':
            Utterance[seg][band] = GetSerial();
            Utterance[seg][band] += 256*GetSerial();
//      case 's':
//        ShiftUtterance(Utterance,Utterance2,(int8_t)GetSerial());
//        Serial.println('s');
//        SendUtterance(Utterance2);
//        break;
//      case 'd':
//        Serial.println('d');
//        i = (int8_t)GetSerial();
//        j = (int8_t)GetSerial();
//        Serial.println(ShiftedDistance(Utterance, i, j));
//        break;
//      case 'b':
//        Serial.println('b');
//        Serial.println(FindBestShift(Utterance, GetSerial()));
//        break;
      case 'b':
        bAnalyse = false; // не анализировать фразы - мы просто собираем данные
      case 'c':
        Serial.println('c');
        bAnalyse = true; // анализировать фразы
      case 'f':
        Serial.println('f');
        AnalyseUtterance(Utterance);
// setup
void setup(void)
  Serial.begin(57600);
  Serial.println("speechrecog");
  pinMode(AUDIO_IN, INPUT);
  adcAttachPin(AUDIO_IN);
  analogSetAttenuation(ADC_11db);
  analogSetWidth(12);
  analogRead(AUDIO_IN); // инициализация АЦП для чтения аудио-сигнала
  Serial.println("0 0 0 0 0 0 350");
  PollBands(true);
// Основные процедуры
// loop
void loop(void)
  CheckSerial();
  PollBands(false);
Link to article: https://www.instructables.com/Speech-Re ... uino-Nano/
Thank you in advance.
MicroController
Re: Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Error Esp32
Postby MicroController » Sat Sep 16, 2023 9:59 am
Connect to the ESP via idf.py monitor to get the backtrace resolved to corresponding code lines/functions.
Users browsing this forum: PetalBot and 3 guests
