mesh_rssi_threshold_t has no documentation at all
martins
Postby martins » Tue Sep 19, 2023 8:58 am
Hello, I'm trying to adjust connetion rssi thresholds in ESP-WIFI-MESH and found following in esp_mesh_internal.h :
typedef struct {
    int duration_ms;   /* parent weak RSSI monitor duration, if the RSSI continues to be weak during this duration_ms, device will search for a new parent. */
    int cnx_rssi;      /* RSSI threshold for keeping a good connection with parent.
                          If set a value greater than -120 dBm, a timer will be armed to monitor parent RSSI at a period time of duration_ms. */
    int select_rssi;   /* RSSI threshold for parent selection. It should be a value greater than switch_rssi. */
    int switch_rssi;   /* Disassociate with current parent and switch to a new parent when the RSSI is greater than this set threshold. */
    int backoff_rssi;  /* RSSI threshold for connecting to the root */
} mesh_switch_parent_t;
typedef struct {
    int high;
    int medium;
    int low;
} mesh_rssi_threshold_t;
While the mesh_switch_parent_t has at least some comments to get a hint of what it is doing, the mesh_rssi_threshold_t has none whatsoever, ohter than its default values.
Source code for `esp_err_t esp_mesh_set_rssi_threshold(const mesh_rssi_threshold_t *threshold)` is closed so I have no way to figure this out. Could you please clarify what are these levels for?
zhangyanjiao
Re: mesh_rssi_threshold_t has no documentation at all
Postby zhangyanjiao » Wed Sep 27, 2023 9:33 am
`esp_err_t esp_mesh_set_rssi_threshold(const mesh_rssi_threshold_t *threshold)` is used to set the RSSI threshold of the current parent. And if the parent's rssi is lower than `threshold->low` for a period time of `duration_ms`, then the mesh node will post `MESH_WEAK_RSSI` event.
The `threshold->low`, `threshold->high`, `threshold->medium` also be used when the mesh node want to switch parent, they are used to determine whether the new parent and the current parent are in the same rssi range.
Users browsing this forum: Bing [Bot] and 2 guests
