Enable BT5 only, not Classic 4
JustDaveIII
Postby JustDaveIII » Sun Sep 24, 2023 7:33 pm
I have a need to use only BT5, for the ESP32-C3.
I'm seeing:
"#define CONFIG_BT_CLASSIC_ENABLED 1"
in the .h files and it used in the BLEDevice.cpp code. I comment it out in all the .h files in hopes of not having BT Classic 4 broadcast because in the .cpp code I see:
#ifndef CONFIG_BT_CLASSIC_ENABLED
yada yada
#else
So I think just "#define CONFIG_BT_CLASSIC_ENABLED 0 "
won't work (yes I tried that first).
Unfortunately this does not work. How can I disable BT4?
As a side note, I'll also want to set the transmit power level to maximum and/or enable long range. How?
Re: Enable BT5 only, not Classic 4
Postby Sprite » Mon Sep 25, 2023 12:15 am
The ESP32-C3 hardware does not have support for BT Classic in the first place, so independent of those variables it'll always be disabled.
JustDaveIII
Postby JustDaveIII » Wed Sep 27, 2023 7:20 pm
Really? Then why can I see the packets sent from it on my old Android phone that only supports BT4?
Maybe I was not clear. I need/want only BT5.
My Android Alcatel Onetouch phone does not do BT5, just 4. My iPhone SE3 does BT5. My iPhone 6S+ is BT4.2. The app I'm using says the ESP-32-C3 is transmitting BT4 , on all 3 phones. Even on the phones that cannot ever do BT5.
BTW it's the Drone Scanner app and the ESP32-c3 app is based on OpenDroneID: https://github.com/sxjack/uav_electroni ... _esp32.cpp
Postby Sprite » Thu Sep 28, 2023 3:47 am
Possibly because the phone has a dual-stack BT setup. BLE already existed during BT4's lifetime as well. (For instance, the original ESP32 is BT4.2 and has BLE.)
