ESP-IDF 5.1.1 gatt_server identifier "CONFIG_BT_LE_LL_RESOLV_LIST_SIZE" is undefined
caetanowagner
Postby caetanowagner » Tue Sep 26, 2023 5:48 pm
Hi guys, just got an error.
I did a fresh install from Espressif extension and created a new project based on gatt_server and I left all default config.
Get this erros
Code: Untitled.txt Select all
from
gatts_demo.c line 687
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
Os: Ubuntu 22.04.3 LTS
Any ideia how to fix it?
Thanks.
Doctor command:
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS linux x64 6.2.0-33-generic
System environment variable IDF_PYTHON_ENV_PATH
undefined
System environment variable PATH
<HOMEPATH>/.local/bin:<HOMEPATH>/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:<HOMEPATH>/dev/flutter/bin
System environment variable PYTHON
undefined
Visual Studio Code version 1.82.2
Visual Studio Code language en
Visual Studio Code shell /usr/bin/bash
ESP-IDF Extension version 1.6.4
Workspace folder <HOMEPATH>/esp/workspace/medidor_de_pasto
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) <HOMEPATH>/esp/esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
ESP-Matter Path (idf.espMatterPath) ${env:ESP_MATTER_PATH}
Custom extra paths (idf.customExtraPaths) <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/12.1_20221002/xtensa-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/12.1_20221002/riscv32-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-12.2.0_20230208/xtensa-esp32-elf/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32s2-elf/esp-12.2.0_20230208/xtensa-esp32s2-elf/bin:<HOMEPATH>/.espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-12.2.0_20230208/riscv32-esp-elf/bin:<HOMEPATH>/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin:<HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/bin:<HOMEPATH>/.espressif/tools/esp-rom-elfs/20230320
Custom extra vars (idf.customExtraVars)
OPENOCD_SCRIPTS: <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/share/openocd/scripts
ESP_ROM_ELF_DIR: <HOMEPATH>/.espressif/tools/esp-rom-elfs/20230320/
Virtual env Python Path (idf.pythonBinPath) <HOMEPATH>/.espressif/python_env/idf5.1_py3.10_env/bin/python
Serial port (idf.port) /dev/ttyUSB1
OpenOCD Configs (idf.openOcdConfigs) board/esp32-wrover-kit-3.3v.cfg
ESP-IDF Tools Path (idf.toolsPath) <HOMEPATH>/.espressif
Git Path (idf.gitPath) git
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espAdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espMdfPath) false
Access to ESP-Matter Path (idf.espMatterPath) false
Access to ESP-IDF Custom extra paths
Access to <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/12.1_20221002/xtensa-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/12.1_20221002/riscv32-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-12.2.0_20230208/xtensa-esp32-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32s2-elf/esp-12.2.0_20230208/xtensa-esp32s2-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-12.2.0_20230208/riscv32-esp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/bin: true
Access to <HOMEPATH>/.espressif/tools/esp-rom-elfs/20230320: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH true
Access to Ninja in environment PATH true
Access to ESP-IDF Tools Path (idf.toolsPath) true
-------------------------------------------------------- Configurations has spaces -------------------------------------------------------------
Spaces in system environment Path false
Spaces in ESP-ADF Path (idf.espAdfPath) false
Spaces in ESP-IDF Path (idf.espIdfPath) false
Spaces in ESP-MDF Path (idf.espMdfPath) false
Spaces in ESP-Matter Path (idf.espMatterPath) false
Spaces in ESP-IDF Custom extra paths
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/12.1_20221002/xtensa-esp-elf-gdb/bin: false
Spaces in <HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/12.1_20221002/riscv32-esp-elf-gdb/bin: false
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-12.2.0_20230208/xtensa-esp32-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp32s2-elf/esp-12.2.0_20230208/xtensa-esp32s2-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-12.2.0_20230208/riscv32-esp-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/esp32ulp-elf/2.35_20220830/esp32ulp-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20230419/openocd-esp32/bin: false
Spaces in <HOMEPATH>/.espressif/tools/esp-rom-elfs/20230320: false
Spaces in Virtual env Python Path (idf.pythonBinPath) false
Spaces in ESP-IDF Tools Path (idf.toolsPath) false
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.34.1
ESP-IDF version 5.1.1
Python version 3.10.12
Python's pip version 23.2.1
-------------------------------------------------- Project configuration settings ----------------------------------------------------------
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
bitarray version: 2.8.1
bitstring version: 4.1.2
CacheControl version: 0.13.1
certifi version: 2023.7.22
cffi version: 1.15.1
charset-normalizer version: 3.2.0
click version: 8.0.4
colorama version: 0.4.6
construct version: 2.10.68
contextlib2 version: 21.6.0
cryptography version: 39.0.2
ecdsa version: 0.18.0
esp-coredump version: 1.7.0
esp-debug-backend version: 1.0.3
esp-idf-kconfig version: 1.2.0
esp-idf-monitor version: 1.2.1
esp-idf-panic-decoder version: 0.1.0
esp-idf-size version: 0.4.2
esptool version: 4.7.dev1
filelock version: 3.12.4
freertos-gdb version: 1.0.2
gcovr version: 6.0
idf-component-manager version: 1.4.0
idna version: 3.4
Jinja2 version: 3.0.3
kconfiglib version: 14.1.0
lxml version: 4.9.3
MarkupSafe version: 2.1.3
msgpack version: 1.0.5
packaging version: 23.1
pip version: 23.2.1
pycparser version: 2.21
pyelftools version: 0.29
pygdbmi version: 0.9.0.2
Pygments version: 2.16.1
pyparsing version: 3.0.9
pyserial version: 3.5
PyYAML version: 6.0.1
reedsolo version: 1.7.0
requests version: 2.31.0
requests-file version: 1.5.1
requests-toolbelt version: 1.0.0
schema version: 0.7.5
setuptools version: 68.2.2
six version: 1.16.0
tqdm version: 4.66.1
urllib3 version: 1.26.16
websocket-client version: 1.6.3
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages Python requirements are satisfied.
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages Python requirements are satisfied.
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages Python requirements are satisfied.
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch"
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
"configurations": [
"name": "ESP-IDF",
"compilerPath": "<HOMEPATH>/.espressif/tools/xtensa-esp32-elf/esp-12.2.0_20230208/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc",
"includePath": [
"${config:idf.espIdfPath}/components/**",
"${config:idf.espIdfPathWin}/components/**",
"${config:idf.espAdfPath}/components/**",
"${config:idf.espAdfPathWin}/components/**",
"${workspaceFolder}/**"
"browse": {
"path": [
"${config:idf.espIdfPath}/components",
"${config:idf.espIdfPathWin}/components",
"${workspaceFolder}"
"limitSymbolsToIncludedHeaders": false
"version": 4
aurxine
Re: ESP-IDF 5.1.1 gatt_server identifier "CONFIG_BT_LE_LL_RESOLV_LIST_SIZE" is undefined
Postby aurxine » Tue Jun 11, 2024 6:35 am
I faced the similar problem. Clicking on "BT_CONTROLLER_INIT_CONFIG_DEFAULT();" took me to esp32h4/include/bt.h instead of esp32c3/include/bt.h, which means vscode was replacing the default config to that of esp32h4 instead of esp32c3 (which I'm actually working on).
Adding "compileCommands": "${workspaceFolder}/build/compile_commands.json" in "configurations" of my c_cpp_configurations.json did fix this error but added more include errors in gatts_demo.c file. So I did a fullclean on my project and built the project using the ESP-IDF extension. This fixed all my problems.
toeCutter
Postby toeCutter » Mon Oct 27, 2025 9:03 pm
I have the same issue with that simple code:
#include "esp_bt.h"
void init_bluetooth() {
// Initialize the Bluetooth controller
esp_bt_controller_init(&bt_cfg);
esp_bt_controller_enable(ESP_BT_MODE_BLE);
// Initialize Bluedroid stack
esp_bluedroid_init();
esp_bluedroid_enable();
toeCutter
Postby toeCutter » Wed Oct 29, 2025 9:13 pm
I tried with ESP-IDF 5.4.3 and it is working.
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
