Arduino IDE with PDM
siab14
Postby siab14 » Thu Sep 28, 2023 10:57 am
Code: Untitled.cpp Select all
I'm working on a program which is communicating via PDM with a microphone (IM72D128V01) from the ESP32-S3-WROOM-2 (Devkit-C).
I believe this is supported by the ESP32, although getting it to work via the Arduino IDE has proved difficult to me. I am getting some bits of information in the buffer every time I reset, but not a constant stream of data.
Any advice or working examples of similar would be much appreciated!
#include <I2S.h>
const int buff_size = 128;
uint8_t buffer[buff_size];
const int sclkPin = 14;
const int wsPin = 3;
const int sdataPin = 16;
const int outSdPin = 9;
const int inSdPin = 10;
const int bufferSize = 128;
int readD;
//SCK (Serial Clock): is the clock signal also referred as BCLK (Bit Clock Line);
//FS (Frame Select): used to discriminate Right or Left Channel data also referred WS (Word Select);
//SD (Serial Data): the serial data to be transmitted;
//Frequency = SampleRate x BitsPerChannel x numberOfChannels
// begin(int mode, int sampleRate, int bitsPerSample)
void setup()
  I2S.setAllPins(sclkPin, wsPin, sdataPin, outSdPin, inSdPin);
  I2S.setBufferSize(bufferSize);
  I2S.setDuplex();
  I2S.begin(PDM_MONO_MODE, 4000, 16);
  I2S.read(); // Switch the driver in simplex mode to receive
  /* Modes:
    I2S_PHILIPS_MODE
    I2S_RIGHT_JUSTIFIED_MODE
    I2S_LEFT_JUSTIFIED_MODE
    PDM_MONO_MODE
  I2S.setSimplex();
void loop()
  I2S.read();
  Serial.println(I2S.available());
  if(I2S.available() < buff_size)
    readD = I2S.read(buffer, I2S.available());
  else
    readD = I2S.read(buffer, buff_size);
  Serial.println(readD);
  Serial.println("");
Shanjai_247
Re: Arduino IDE with PDM
Postby Shanjai_247 » Tue Apr 15, 2025 3:35 pm
Hi, I'm also working on a similar project where I'm using the IM69D130 mic. Were you able to successfully read data from the PDM mic in the Arduino IDE? I need to read the PDM data and convert it to PCM for FFT.
Would be great help if you could share any information. Thanks!
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 1 guest
