Unable to use the whole memory in ESP32 with Arduino
gchini
Postby gchini » Fri Sep 29, 2023 5:39 am
I have a problem in the amout of memory allocated in my esp32
Basically i want use the Whole potentiality of my esp32 in particular the whole memory about 400k. I chosed ESP32 for this reason. I've tried it on the Raspberry PI Pico W and it works well but i want change platform because esp is cheaper.
The problem is that when I'm calling a function that calls other functions it gives me the error "***ERROR*** A stack overflow in task newloop has been detected."
I've investigated the reason and i putted in my program the follow code:
void newloop(void* param) {
  //MY CODE
  xTaskCreateUniversal(newloop,"newloop", 32*1024, NULL, 1, NULL, ARDUINO_RUNNING_CORE);
  vTaskDelete(NULL);
void loop() {}
But unsucessfully, the error stil appear.
I qant higllight that my code soes not user dynamic allocation and all variables and structures are allocated directly in the stack statically,
What i can do?
andpet
Re: Unable to use the whole memory in ESP32 with Arduino
Postby andpet » Sat Sep 30, 2023 6:26 am
Increase the 32*1024 argument or change your large allocations from the stack to static allocations.
You can also switch to xTaskCreateStatic() to allocate the task stack at compile-time. It doesn't change how much memory is available but it does show already at compile-time how much RAM is used instead of waiting until the program crashes.
MicroController
Postby MicroController » Sat Sep 30, 2023 5:39 pm
What i can do?
viewtopic.php?f=13&t=35960#p121185
Don't use the stack/local variables for all your memory needs. Use globals or heap memory.
