Hi
I tried the example "wear_levelling" in esp32 to store some data in the SPI flash, for working with this example we changed the partition type to csv and made a partition "partitions_example.csv" and it is working, writing and reading in spi flash happening. But i need to work with OTA also same time, but for OTA the partition type is different, if i change to it the spi flash write wont work, How i can fix it, Any suggestion please.
How i can use OTA and SPI flash together
Re: How i can use OTA and SPI flash together
I'm also interested in this. I'd like to update a SPIFFS partition with OTA. However, the documentation is clear that the OTA partition must of the app type with ota_x subtype. I tried to mount a SPIFFS partition with those settings in the partition table. Not surprisingly, it failed:
Are there any known workarounds for this? Any future plans for extending OTA beyond the app partitions?
E (272) SPIFFS: spiffs partition could not be found
If you need to update a non-OTA partition, you should be able to just use the SPI flash partition read/write/erase API. Just make sure the spiffs is unmounted first.
I think we just need some idiomatic way to handle files upload for file update in spiffs. I believe kolban's book has some secret recipe for this.If you need to update a non-OTA partition, you should be able to just use the SPI flash partition read/write/erase API. Just make sure the spiffs is unmounted first.
Dose ESP-IDF has a webserver as a stock component? I can image how to get new "app.bin" and all files that need to be updated in spiffs from SD card through the right now APIs from ESP-IDF. But how to update these files wirelessly?
Cheers
Gfast2
Users browsing this forum: Baidu [Spider], Google [Bot], PerplexityBot, YisouSpider and 4 guests
