How to set the mDNS instance name
huoxingdigua
The default mDNS instance name is the service name with -xx number suffix. How to change it from AT command?
Re: How to set the mDNS instance name
instance name is set by mdns_service_add(), and it should be same as the service name. could you please provide more details, such as logs and capture the packets, etc.
huoxingdigua
Thanked your reply.
My question is how to change it by AT command.
you could change service name by AT+MDNS command: https://docs.espressif.com/projects/esp ... s-function
