espflash - No target specified in cargo configuration - how to fix it ?
35p32fan
Postby 35p32fan » Thu Oct 12, 2023 1:08 pm
using Debian 12 (x86_64)
Device: ESP32-2432S028R
but did not get it work.... what did I wrong ?
Code: Untitled.txt Select all
cargo install espup
git clone https://github.com/esp-rs/esp-idf-hal
cd esp-idf-hal
$ cargo espflash board-info
[2023-10-12T12:56:16Z INFO ] Serial port: '/dev/ttyUSB0'
[2023-10-12T12:56:16Z INFO ] Connecting...
[2023-10-12T12:56:16Z INFO ] Using flash stub
Chip type: esp32 (revision v3.1)
Crystal frequency: 40MHz
Flash size: 4MB
MAC address: 08:d1:f9:xx:xx:xx
$ cargo espflash flash --example=blinky --monitor
[2023-10-12T12:59:54Z INFO ] Serial port: '/dev/ttyUSB0'
[2023-10-12T12:59:54Z INFO ] Connecting...
[2023-10-12T12:59:54Z INFO ] Using flash stub
Error: cargo_espflash::no_target
× Failed to build project
╰─▶ No target specified in cargo configuration
help: Specify the target in `.cargo/config.toml`, the esp32 support the following targets: xtensa-esp32-none-elf, xtensa-esp32-espidf
$ cat .cargo/config.toml
[target.'cfg(any(target_arch = "riscv32", target_arch = "xtensa"))']
runner = "espflash flash --monitor"
[target.xtensa-esp32-none-elf]
linker = "ldproxy"
[target.xtensa-esp32-espidf]
linker = "ldproxy"
[target.xtensa-esp32s2-espidf]
linker = "ldproxy"
[target.xtensa-esp32s3-espidf]
linker = "ldproxy"
[target.riscv32imc-esp-espidf]
linker = "ldproxy"
[target.riscv32imac-esp-espidf]
linker = "ldproxy"
[env]
ESP_IDF_SDKCONFIG_DEFAULTS = ".github/configs/sdkconfig.defaults"
[unstable]
build-std = ["std", "panic_abort"]
build-std-features = ["panic_immediate_abort"]
Users browsing this forum: Bing [Bot], ChatGPT-User and 3 guests
