使用flash_download_tool_3.9.3擦除分区后,重新烧录分区,查看日志出现很多坏快,文件系统使用littlefs(fatfs不适用项目,乐鑫官网有推荐这个文件系统)
flquchi
Postby flquchi » Fri Oct 13, 2023 7:24 am
ets Jul 29 2019 12:21:46
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6668
ho 0 tail 12 room 4
load:0x40078000,len:15040
load:0x40080400,len:3816
entry 0x40080698
[0;32mI (29) boot: ESP-IDF v4.4.4-dirty 2nd stage bootloader[0m
[0;32mI (30) boot: compile time 09:51:59[0m
[0;32mI (30) boot: chip revision: v3.1[0m
[0;32mI (33) boot_comm: chip revision: 3, min. bootloader chip revision: 0[0m
[0;32mI (40) boot.esp32: SPI Speed : 40MHz[0m
[0;32mI (45) boot.esp32: SPI Mode : DIO[0m
[0;32mI (49) boot.esp32: SPI Flash Size : 16MB[0m
[0;32mI (54) boot: Enabling RNG early entropy source...[0m
[0;32mI (59) boot: Partition Table:[0m
[0;32mI (63) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (70) boot: 0 phy_init RF data 01 01 00009000 00001000[0m
[0;32mI (78) boot: 1 ota_data OTA data 01 00 0000a000 00002000[0m
[0;32mI (85) boot: 2 nvs WiFi data 01 02 0000c000 00024000[0m
[0;32mI (93) boot: 3 factory factory app 00 00 00030000 00230000[0m
[0;32mI (100) boot: 4 backup test app 00 20 00260000 00230000[0m
[0;32mI (108) boot: 5 ota_0 OTA app 00 10 00490000 00230000[0m
[0;32mI (115) boot: 6 ota_1 OTA app 00 11 006c0000 00230000[0m
[0;32mI (123) boot: 7 storage Unknown data 01 81 008f0000 00400000[0m
[0;32mI (130) boot: 8 factory_storage Unknown data 01 81 00cf0000 00100000[0m
[0;32mI (138) boot: 9 backup_storage Unknown data 01 81 00df0000 00210000[0m
[0;32mI (145) boot: End of partition table[0m
[0;32mI (150) boot: Defaulting to factory image[0m
[0;32mI (154) boot_comm: chip revision: 3, min. application chip revision: 0[0m
[0;32mI (162) esp_image: segment 0: paddr=00030020 vaddr=3f400020 size=5d9a4h (383396) map[0m
[0;32mI (309) esp_image: segment 1: paddr=0008d9cc vaddr=3ffbdb60 size=0264ch ( 9804) load[0m
[0;32mI (313) esp_image: segment 2: paddr=00090020 vaddr=400d0020 size=150d78h (1379704) map[0m
[0;32mI (814) esp_image: segment 3: paddr=001e0da0 vaddr=3ffc01ac size=039ech ( 14828) load[0m
[0;32mI (820) esp_image: segment 4: paddr=001e4794 vaddr=40080000 size=1ddech (122348) load[0m
[0;32mI (885) boot: Loaded app from partition at offset 0x30000[0m
[0;32mI (885) boot: Disabling RNG early entropy source...[0m
[0;32mI (897) psram: This chip is ESP32-D0WD[0m
[0;32mI (898) spiram: Found 64MBit SPI RAM device[0m
[0;32mI (898) spiram: SPI RAM mode: flash 40m sram 40m[0m
[0;32mI (902) spiram: PSRAM initialized, cache is in low/high (2-core) mode.[0m
[0;32mI (910) cpu_start: Pro cpu up.[0m
[0;32mI (913) cpu_start: Starting app cpu, entry point is 0x400817d0[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (1810) spiram: SPI SRAM memory test OK[0m
[0;32mI (1819) cpu_start: Pro cpu start user code[0m
[0;32mI (1819) cpu_start: cpu freq: 240000000[0m
[0;32mI (1819) cpu_start: Application information:[0m
[0;32mI (1822) cpu_start: Project name: FL2740[0m
[0;32mI (1827) cpu_start: App version: 1.1.5[0m
[0;32mI (1832) cpu_start: Compile time: Sep 26 2023 09:51:54[0m
[0;32mI (1838) cpu_start: ELF file SHA256: 4d5f33c481786cec...[0m
[0;32mI (1844) cpu_start: ESP-IDF: v4.4.4-dirty[0m
[0;32mI (1850) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1857) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM[0m
[0;32mI (1863) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM[0m
[0;32mI (1869) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM[0m
[0;32mI (1875) heap_init: At 3FFCEC38 len 000113C8 (68 KiB): DRAM[0m
[0;32mI (1881) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (1888) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (1894) heap_init: At 4009DDEC len 00002214 (8 KiB): IRAM[0m
[0;32mI (1901) spiram: Adding pool of 4084K of external SPI memory to heap allocator[0m
[0;32mI (1910) spi_flash: detected chip: generic[0m
[0;32mI (1913) spi_flash: flash io: dio[0m
[0;32mI (1918) sleep: Configure to isolate all GPIO pins in sleep state[0m
[0;32mI (1924) sleep: Enable automatic switching of GPIO sleep configuration[0m
[0;32mI (1932) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (1942) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations[0m
[0;32mI (1952) gpio: GPIO[33]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 [0m
[0;32mI (1962) fl_ota: ota_init !!![0m
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x4c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x4d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x4e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x4f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x50
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x51
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x52
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x53
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x54
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x55
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x56
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x57
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x58
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x59
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x5f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x60
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x61
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x62
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x63
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x64
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x65
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x66
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x67
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x68
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x69
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x6f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x70
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x71
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x72
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x73
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x74
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x75
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x76
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x77
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x78
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x79
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x7f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x80
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x81
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x82
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x83
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x84
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x85
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x86
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x87
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x88
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x89
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x8f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x90
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x91
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x92
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x93
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x94
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x95
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x96
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x97
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x98
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x99
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x9f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xa9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xaa
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xab
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xac
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xad
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xae
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xaf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xb9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xba
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xbb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xbc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xbd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xbe
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xbf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xc9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xca
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xcb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xcc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xcd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xce
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xcf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xd9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xda
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xdb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xdc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xdd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xde
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xdf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xe9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xea
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xeb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xec
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xed
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xee
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xef
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xf9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xfa
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xfb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xfc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xfd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xfe
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0xff
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x100
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x101
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x102
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x103
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x104
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x105
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x106
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x107
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x108
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x109
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x10f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x110
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x111
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x112
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x113
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x114
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x115
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x116
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x117
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x118
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x119
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x11f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x120
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x121
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x122
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x123
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x124
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x125
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x126
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x127
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x128
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x129
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x12f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x130
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x131
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x132
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x133
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x134
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x135
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x136
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x137
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x138
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x139
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x13f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x140
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x141
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x142
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x143
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x144
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x145
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x146
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x147
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x148
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x149
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x14f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x150
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x151
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x152
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x153
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x154
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x155
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x156
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x157
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x158
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x159
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x15f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x160
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x161
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x162
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x163
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x164
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x165
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x166
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x167
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x168
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x169
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x16f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x170
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x171
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x172
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x173
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x174
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x175
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x176
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x177
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x178
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x179
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x17f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x180
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x181
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x182
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x183
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x184
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x185
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x186
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x187
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x188
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x189
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x18f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x190
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x191
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x192
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x193
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x194
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x195
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x196
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x197
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x198
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x199
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x19f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1a9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1aa
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ab
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ac
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ad
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ae
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1af
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1b9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ba
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1bb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1bc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1bd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1be
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1bf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1c9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ca
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1cb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1cc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1cd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ce
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1cf
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1d9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1da
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1db
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1dc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1dd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1de
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1df
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1e9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ea
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1eb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ec
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ed
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ee
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ef
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f0
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f1
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f2
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f3
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f4
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f5
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f6
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f7
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f8
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1f9
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1fa
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1fb
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1fc
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1fd
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1fe
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x1ff
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x200
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x201
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x202
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x203
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x204
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x205
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x206
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x207
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x208
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x209
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x20f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x210
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x211
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x212
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x213
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x214
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x215
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x216
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x217
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x218
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x219
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x21f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x220
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x221
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x222
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x223
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x224
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x225
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x226
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x227
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x228
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x229
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x22f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x230
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x231
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x232
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x233
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x234
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x235
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x236
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x237
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x238
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x239
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23b
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23c
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23d
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23e
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x23f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x240
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x241
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x242
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x243
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x244
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x245
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x246
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x247
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x248
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x249
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x24a
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x24f
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x250
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x251
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x252
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x253
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x254
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x255
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x256
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x257
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x258
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:584:error: No more free space 1625
IDF/platform/Buildlib_project/components/OS/littlefs/lfs.c:1882:debug: Bad block at 0x24e
