WiFi factory reset - how to?
cskilbeck
Postby cskilbeck » Fri Oct 13, 2023 9:58 am
Is the following code a reasonable way to factory reset the wifi credentials?
Code: Untitled.c Select all
void wifi_factory_reset()
wifi_config_t blank_config;
memset(&blank_config, 0, sizeof(blank_config));
ESP_ERROR_CHECK(esp_wifi_disconnect());
ESP_ERROR_CHECK(esp_wifi_stop());
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &blank_config));
ESP_ERROR_CHECK(esp_wifi_start());
Re: WiFi factory reset - how to?
Postby Sprite » Sat Oct 14, 2023 1:08 am
Probably better to just stop WiFi and then nuke the WiFi NVS partition.
Users browsing this forum: Baidu [Spider], Semrush [Bot], YisouSpider and 8 guests
