ESP32 (WT32-ETH01) and TLC5973 LED Driver - Flickering issue
juma08
Postby juma08 » Sat Oct 14, 2023 3:15 pm
Hello everyone,
I’m facing issues with the TLC5973 LED driver when paired with the WT32-ETH01 microcontroller. In my project using Arduino I use the TLC5973 to control LEDs. When I try dimming just one color, everything works perfectly. However, as soon as I dim two or three colors, at high brightness flickering starts to occur.
I have a stable power supply and adding a capacitor didn’t make a difference. After some debugging and using an oscilloscope, I noticed that some of the PWM pulses from the TLC appear shorter than they should be. This might explain the flickering.
I’ve attempted several things but turning off the WiFi and Bluetooth on the WT32-ETH01 with WiFi.mode(WIFI_OFF); and btStop(); commands seemed to help a lot, but the flickering is still not entirely gone. Therefore I assume it could be an Issue with the timing or Interrupts which occur.
Has anyone had experience with this hardware combination or can offer tips on optimizing the timing? Is it feasible to rewrite the library to be better suited for the TLC5973 and the WT32-ETH01?
my code looks like this to fade the LEDs:
Code: Untitled.cpp Select all
#include <TLC5973.h>
#include <WiFi.h>
#include "esp_bt.h"
byte LED = 4;
uint16_t N = 1; // One LED on each output
TLC5973 strip = TLC5973(N, LED);
int fadeValue = 0; // Start with LED off
bool increasing = true; // Direction of fade
const long intervalFade = 10; // interval for fading (milliseconds)
unsigned long previousMillis = 0;
// WiFi.mode(WIFI_OFF); //To turn Wifi off
// btStop();
Serial.begin(9600);
strip.begin();
strip.setPixelColor(0, 0, 0, 0);
strip.show(); //Send Data
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= intervalFade) {
if (increasing) {
fadeValue += 1;
if (fadeValue >= 4095) {
increasing = false;
fadeValue -= 1;
if (fadeValue <= 0) {
increasing = true;
strip.setPixelColor(0, fadeValue, fadeValue, fadeValue);
strip.show();
previousMillis = currentMillis;
The routine out of the TLC5973.cpp which sends the data looks like this:
void TLC5973::show(){
noInterrupts(); // Need 100% focus on instruction timing
for(uint16_t i = 0; i < numWords; i=i+3){
writeWord( 0x03AA); //Start
writeWord( pixels[i] );
writeWord( pixels[i+1] );
writeWord( pixels[i+2] );
waitGSLAT(4);
waitGSLAT(4);
interrupts();
I already deactivated Interrupts before the communication but when WIFI and bluetooth are ON there is massive Flickering at the LEDs. The TLC5973 documents are attached.
Any help or recommendations would be greatly appreciated!
Thanks in advance.
TLC5973.h
(728 Bytes) Downloaded 405 times
TLC5973.cpp
(1.82 KiB) Downloaded 413 times
juma08
Re: ESP32 (WT32-ETH01) and TLC5973 LED Driver - Flickering issue
Postby juma08 » Tue Oct 17, 2023 10:56 am
I solved the flickering Issue for WIFI / BT OFF. I had to adjust the number of NOPs in the TLC5973.cpp to fit the Timing.
void TLC5973::writeZero(){
    pulse();
    NOP;
    NOP;
    NOP;
    NOP;
void TLC5973::writeNone(){
       NOP;
       NOP;
       NOP;
       NOP;
       NOP;
       NOP;
       NOP;
       NOP;
But still while WIFI /BT ON there is massive flickering. I think the Timing needs to be adjusted for this use case to deal with the Interrupts of WIFI / BT. Maybe something like this WS2812 firmware attached. They use a combination with Inline-Assambler...
Users browsing this forum: Bytespider and 2 guests
