Hello people
I actually have a problem to compile and program the sample code from XT_DAC_Audio on a ESP32
I use Arduino IDE 2.2.2
I have downloaded the archive : https://www.xtronical.com/wp-content/up ... -4_2_1.zip
I have downloaded the board ESP32 Dev Module
When I try to verify the sample code "PlayWav" from the archive, i get this error message :
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o:(.literal._Z4loopv+0xc): undefined reference to `XT_DAC_Audio_Class::FillBuffer()'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o:(.literal._Z4loopv+0x10): undefined reference to `XT_DAC_Audio_Class::Play(XT_PlayListItem_Class*)'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_Force+0x4): undefined reference to `XT_Wav_Class::XT_Wav_Class(unsigned char const*)'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o:(.literal.startup._GLOBAL__sub_I_Force+0x8): undefined reference to `XT_DAC_Audio_Class::XT_DAC_Audio_Class(unsigned char, unsigned char)'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o: in function `loop()':
C:\Users\POXA\Downloads\XT_DAC_Audio-4_2_1\XT_DAC_Audio\PlayWav/PlayWav.ino:27: undefined reference to `XT_DAC_Audio_Class::FillBuffer()'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\Downloads\XT_DAC_Audio-4_2_1\XT_DAC_Audio\PlayWav/PlayWav.ino:29: undefined reference to `XT_DAC_Audio_Class::Play(XT_PlayListItem_Class*)'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o: in function `_GLOBAL__sub_I_Force':
C:\Users\POXA\Downloads\XT_DAC_Audio-4_2_1\XT_DAC_Audio\PlayWav/PlayWav.ino:10: undefined reference to `XT_Wav_Class::XT_Wav_Class(unsigned char const*)'
c:/users/poxa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\POXA\AppData\Local\Temp\arduino\sketches\779E847158478B338F628AEEE3C2E49C\sketch\PlayWav.ino.cpp.o: in function `__static_initialization_and_destruction_0':
C:\Users\POXA\Downloads\XT_DAC_Audio-4_2_1\XT_DAC_Audio\PlayWav/PlayWav.ino:13: undefined reference to `XT_DAC_Audio_Class::XT_DAC_Audio_Class(unsigned char, unsigned char)'
exit status 1
Compilation error: exit status 1
It looks like something is not well referenced, but i don't why, because i took everything from the archive and added it to library
Can someone has a clue or an idea of what i can/should do to success
Thanks in advance
Error Compiling
lbernstone
Re: Error Compiling
I installed with git from https://github.com/WeekendWarrior1/XTro ... dio_Mirror
Compiled without problems. Perhaps you did not put it in the correct location where it could find the functions. (<sketchbook>/libraries/XT_DAC_Audio - it is flat in there)
The include in that playwav.ino really should be #include <XT_DAC_Audio.h> to indicate it is a system provided header rather than local, but that should not cause an error.
Users browsing this forum: meta-externalagent and 2 guests
