Controlling Husqvarna Area Switch
Kweetni01
Postby Kweetni01 » Tue Oct 17, 2023 2:16 pm
I'm new to the ESP. But I was asking myself the question if it would be possible to control my Area Switch via a esp32 and Home Assistant. See photo's. You can see it's a simple manual switch. In the box there is lots of place left for an esp and a battery. In the garden I've got wifi.
So would it be possible to move the switch remotely?
Thanks,
James
Re: Controlling Husqvarna Area Switch
Postby Sprite » Wed Oct 18, 2023 5:51 am
Probably. You'd use a relay to replace the switch, and an ESP32 to control the relay. Suggest looking into ESPHome if you want easy integration with Home Assistant.
